Staple removal tool
Discussion in 'Keychain Tools' started by Alter Rostig, Aug 23, 2009.
  1. Alter Rostig
    Alter Rostig Loaded Pockets
    Hello all,
    I've been thinking of adding a small tool for staple extraction to my pocket carry stuff. Any suggestions as to what is most suitable, whether alone or on an existing multi-tool?
    TIA,
    Jack
  2. Manatakui
    Manatakui Loaded Pockets
    You could get a Pico or Micro Widgy from County Comm, or use the bottle opener as a staple pry from an 84mm-or-larger SAK. :)
  3. Bucky
    Bucky Loaded Pockets
    I still think the hinged staple removers with the four little "teeth" work the best. If you need to remove lots of staples, I would opt for one of those. If not, any small pry bar or flathead screwdirver will do in a pinch.
  4. steelstr45
    steelstr45 Loaded Pockets
  5. indabayou
    indabayou Loaded Pockets
    Pico or Micro Widgy from County Comm. Pico is what i use.
  6. Manatakui
    See, my problem with those is that they tear the staple away, leaving a hole, whereas a pry leaves just the two initial piercing points, and can be carefully restapled without another pair of holes. ;)
  7. RyanMalpiede
    RyanMalpiede Loaded Pockets
    Titanium metal - Works like a champ on office and industrial staples. My one actually spreads the folded over pieces apart since I made the taper :censored: near perfect. (By Accident of course)
  8. copykat
    copykat Loaded Pockets
    I usually just rip them out with my finger nails.
    sometimes you have to unbend the backside first.
    If the staple is a heavy duty I use the big common screwdriver
    on my wave and then use the wave pliers to finish the job.
    A pocket knife works too.
    I been in the copy business tooooo long.
  9. Corbs
    Corbs Loaded Pockets
    I don't find that to be the case when you do the teeth first.
  10. Bucky
    I don't really have an problems with the paper tearing either for the most part as long as you're careful.
  11. schlemshfifty5
    schlemshfifty5 Empty Pockets
    I just use a knife tip. If the staple is stronger than your knife, then it would be better to get a new knife then a "mini pry bar"
  12. jzmtl
    jzmtl Loaded Pockets
    I always carry a SAK and the bottle opener or nail file works great for this.
  13. faca
    faca Loaded Pockets
    I use my nails r keys :-X
  14. sbiner
    sbiner Loaded Pockets
    I would like something like this...a simple, small keychain bar that can be used as many ways as you can imagine. is there something avaliable commercially?
  15. RyanMalpiede
    You can find these on ebay from time to time: Slaymaker
  16. tmedina
    tmedina EDC Junkie!!!!!
    In other words, no. ;D
    -Trevor
    Edit: Joshua Rice does make a thumbnail that comes pretty close.
  17. RyanMalpiede
  18. sbiner
    great collection! does he sell the flat ones also, or were they a limited run?
  19. Corbs
    I've been using a stanley wonderbar for this.
  20. johnnytest
    johnnytest Loaded Pockets
    may I suggest an Artifact... :winkwink:
