Split Rings
Discussion in 'Do-It-Yourself & Gear Modifications' started by The Warrior, Nov 15, 2016.
  1. The Warrior
    The Warrior Loaded Pockets
    Hopefully posting this in the right section.
    Anyone know of a good source for copper split rings? I don't want the jump rings, but the split rings.
    Also, what size would be considered a good size, perhaps 14mm?
    I have some 8mm copper splits, but they're way too small. I'm wanting the same size ring on all my brass/copper key chain gadgets. Thanks.
  2. 0dBm
    0dBm Loaded Pockets
    Copper is too soft as base material for a splitring. Various "copper" splitrings are brass or steel with a copper coat or veneer. I tried these years ago, but have since migrated away from splitting usage.
  3. The Warrior
    Do you use jump rings instead?
  4. 0dBm
    0dBm Loaded Pockets
    I no longer use any kind of metallic ring for my keys. I use paracord in various thickness or leather cord.
  5. tattoosteve99
    tattoosteve99 EDC Junkie!!!
    Unique titanium has some brass,ti, and ss ones.
  6. asemery
    asemery Loaded Pockets
    Depending on the size you need you could click on ********** ETSY
    The Warrior likes this.
  7. Airth
    Airth Loaded Pockets
    I find a lot of the cheaper split rings are actually nickel-plated copper or brass, actually. You could try sanding a bit off to check, then reverse-electroplate it to take off the plating.
