Solar Casio charging questions
Discussion in 'Watches' started by Evil D, Dec 31, 2013.
  1. Evil D
    Evil D Loaded Pockets
    Hey guys, just curious what everyone's battery life is like? Casio's site claims 9 month battery light with no exposure to light for my 7900, but the batter gauge has gone from full charge to low in less than 5 days. Yesterday it dropped to low, so I laid it outside on my porch in the sun all day and it jumped back up to high, and after one day it's back down to medium again. Is this normal or is something wrong? I do have power save function turned on, but I have never seen it in "sleep mode" with the screen turned off. I also have the auto EL function turned on, but it rarely even work when I actually want it to, so I don't think that's running the battery down either.
    Other than that, the only other issue I've had is getting the atomic signal to sync, which is odd because it did it on its own on Christmas day, but now (in the same room) I can't get it to sync up manually, and it hasn't done it successfully on its own since.
  2. Carl Belcher
    Carl Belcher Banned
    That sounds a little odd to me. I'm on my 3rd Casio Solar and I have never seen low battery, it went the med once and that was when I was using the backlight as a flashlight almost constantly one night. I don't use the auto backlight, and when I wake up at night my watch is almost always in sleep mode with the screen blank.
    powerring likes this.
  3. KnoxButler
    KnoxButler Loaded Pockets
    I have a solar Casio Pathfinder and I have never seen the battery charge indicator on anything other than full, even after its been in my watch box with no light for a week or so. I think you should contact Casio's customer support, it sounds like something is not functioning properly. You should be able to keep it in complete darkness for a extended period of time no problem, 5 days with it on your wrist with intermittent exposure to sunlight should be more than enough to keep it fully charged. In the meantime I would turn off the auto EL function. In my experience with two different pathfinder models, the EL function although sometimes useful often illuminates the watch face unnecessarily and being that the back-light is probably the single largest power consumer on the watch it couldn't hurt to just turn it off the auto function and see if your problem improves.
    Soosh and powerring like this.
  4. ox71
    ox71 Loaded Pockets
    Hit the watch against a tabletop, that might get the battery to hold a charge.
    if not it may be bad, they do sell replacements
    casio ctl1616 is the part batterybob has them and info on how to install, if mishandled they short out easily buy touching with fingertips.
  5. Ronin101
    Ronin101 Loaded Pockets
    I think you are overthinking it. I have a GW-300 wich i think was one of the first ones. got it on clearance at walmart for 35.00. It has been on low med high at differnt times and I never do anything with it. never manually set the atomic clock function. just wear and forget. I have been using mine for around 15 years.
  6. ox71
    ox71 Loaded Pockets
    Another bit of info I learned about the solar G's is that if you are putting the watch out to charge, put it in a glass of water, that way the watch doesn't overheat and fry the battery. All day in direct sunlight can do this as well as leaving it on the dashboard in a car.
    try changing it again once or twice and see what happens.
  7. shrap
    shrap Loaded Pockets
    Are you wearing the watch to sleep? If you are an active sleeper, the auto-EL may be going on all night and draining the battery.
    When charging, the battery indicator often shows "high" but when removed from a light source, will instantly drop down to medium. It isn't accurate right after charging.
  8. Omega Man
    Omega Man Loaded Pockets
    I have one that is kept in a jewelry box and I only discover it recharge it maybe once every 12-15 months. I know this isn't good for it, but I just forget its there. The screen usually inactive, but a few hours in the sun and it turns on then starts charging.
  9. MCPOWoller
    MCPOWoller Loaded Pockets
    I've had my Pathfinder PRG-50 since mid 2006 and it has never dropped below mid charge. That was even after I left it in my locker in Iraq while I traveled around the AOR for over a month. One day in the window and it has been fully charged ever since. I'd contact Casio.
  10. Steakslim
    Steakslim Empty Pockets
    As I found out with my casio, the cause of all my battery drainage was the auto EL function. Especially if I have it on while I sleep. Even if you have it off, it is easy to turn it on by accident on my watch in my sleep and it'll just run the juice down quick. Otherwise the battery life is just fine.
  11. Bauzen
    Bauzen Loaded Pockets
    Sometimes my solars go from full to low in the matter of a couple of months, but never 5 days. I have noticed considerably longer battery life when you disable the AutoEL. I often see mine lighting up at night when I'm not asking it to, which drains the battery unnecessarily. If it's dark, pressing the button to light it up isn't that big a deal.
    Only time I ever really need the AutoEL is when I'm riding my motorcycle at night and I can't take both hands off my handlebars to check the time.
  12. neon
    neon Loaded Pockets
    I have my Pathfinder (Protrek) for six years and the battery indicator was on med only when I bought it and removed it from the box. First nice sunny day brought it to full and this never changed. I have never intentionally left my watch on the sun to charge. I just wear it and do not think of the battery. I had the auto EL option on for the first month of owning the watch but turned it off after that and it has been off since.
    My Protrek is PRW-1300.
    Sent from my Nexus 7 using Tapatalk
    SAKplumber likes this.
  13. Darth_Firebolt
    Darth_Firebolt Loaded Pockets
    Yikes. I keep mine around my motorcycle handlebar on long trips. Hope I'm not overheating it.
  14. Shur
    Shur Loaded Pockets
    My 10 year old PRG-80 isnt holding a charge nearly as well as it used to but it will still take a month to go from high to med from a full charge.
    My new way of charging is to leave it on a flat top led bulb I have installed in my bedside lamp. Even after a few hours the watch is barely warmer than it would have been on my wrist.
  15. Handa
    Handa Empty Pockets
    Sounds like the battery is shot. I'd give Casio a call if I were in your shoes.
