Running Headlamp
Discussion in 'Flashlights & Other Illumination Devices' started by M4Lki3r, Jan 29, 2015.
  1. M4Lki3r
    M4Lki3r Loaded Pockets
    I'm going to be running in a Ragnar Relay which is a long distance, multi-day relay race that goes through the night. I'm looking for a lightweight headlamp that can be swapped out so that not every runner needs to buy one, but 2 or 3 will do to be able to swap out. Weight is a concern as some of the legs are 10+ miles. I had a 3xAA one a long time ago that felt like I was getting punched in the forehead every step. Replaceable, cheap batteries preferred to rechargeable, built-in batteries. Comfortable headband for males and females would be nice too.
    [X] I will be mail-ordering or buying online, so this doesn't matter.
    [X] $1-15
    [X] $15-30
    4) Format:
    PART A
    [X] I want a headlamp.
    PART B
    Length:
    [X] 1-2 inches. (Keychain sized)
    [X] 2-4 inches. (Pocket carry)
    PART C
    Width:
    [X] Doesn't matter.
    PART D
    Weight:
    [X] Very light, can't tell it's there.
    [X] Light, no heavier than a few keys or a small car remote.
    5) What kind of "bulb".
    [X] LED - more rugged, unlikely to burn out in your lifetime, less accurate color rendition, in general less output but more efficient (longer runtimes)
    [X] I want common Alkaline batteries. (AA, AAA, C, D)
    [X] I want a rechargeable system. (Not opposed to Eneloops)
    [X] I want to walk around a generally paved area. (15-20 lumens)
    [X] I want to walk unpaved trails. (40 lumens)
    Throw (distance)--------------X--------|----------------------Flood/close-up
    [X] 60-240 min. (1-2 hours)
    [X] 240-360 min. (4-6 hours)
    [X] Very Important (Camping, Backpacking, Car Glove-box.)
    11) Switch Type:
    [X] I don't care.
    12) Switch Location:
    [X] I don't care.
    [X] A simple on-off is fine for me.
    [X] I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
    [X] I don't care.
    [X] Waterproof – how deep: Water Resistant in case of rain
  2. foxmo
    foxmo Loaded Pockets
    Black Diamond Storm. I like Black Diamond headlamps a lot. I use them at work and as a backup bike light. I also have a Zebralight, and it's really really nice, but I stopped using it while running at work because it's metal and not comfortable when it slips and bonks your nose, or when you're running with it around your neck.. Black Diamond headlamps have flood options, spot options, and red light. They're also dimmable from high to low. They have nice headbands too.
    Mudinyeri likes this.
  3. iangineer
    iangineer Loaded Pockets
    This might not help, but I've read before that putting your "head" lamp at closer to chest height gives you a better depth of field when walking/running. Obviously it's better around your head for when doing tasks up close like car repair or under a sink, but when walking/running you're whole body is facing the direction you need the light. I wonder how hard it would be to make a strap to attach a regular headlamp. I was thinking of starting with a heart rate monitor strap or something. Maybe one of those GoPro harnesses, but that seems like overkill.
    When we walk our dogs at night, my wife and I prefer to extend our Black Diamond Spot straps all the way out and hang the lights around our necks and point them at the ground in front of us on the flood setting. It takes the weight off your head and helps to prevent blinding oncoming cars/people.
    Mounting at chest height might also open your search criteria because you could stand a little more weight on your chest than flopping around your head so you could get longer battery life with bigger/more batteries.
    Good luck, sounds fun!
    c99camper likes this.
  4. iangineer
    Double post! I replied to my first post instead of editing...
  5. M4Lki3r
    So after the Ragnar Relay this past weekend, I think I can give the Black Diamond Gizmo Headlamp a decent review for runners.
    Ran with it for about an hour. Had absolutely no problem with it. Was bright enough to see my path about 6ft ahead of me and let people know that I am coming at about 1 in the morning. After the first 3 minutes of getting the brightness and angle adjusted, I completely forget it was even there.
    The band holds in sweat so when we had to trade off to the next runner, it was a little disgusting but that would be expected from any lamp. It was not so heavy that it needed a top strap and it did not bounce against my head at all.
    twin63 likes this.
