Rivet question
Discussion in 'Do-It-Yourself & Gear Modifications' started by Smith28, Oct 3, 2012.
  1. Smith28
    Smith28 Loaded Pockets
    So I'm looking to do the ultra minimalist key modification but am unsure on one point.
    Basically I would want a split ring though the holes of the keys so I could have them on a keychain and never having used pop rivets before I'm not sure whether you are left with a hollow tube or whether it is filled with the pin of metal that's left over.
    Simple question to answer if you know, but I don't! Hope someone can help me.
    Cheers. :)
  2. kevinwho
    kevinwho Loaded Pockets
    Hey , with standard pop rivets there is no hole , as you said it is filled with the remains of the pin
  3. Smith28
    Bugger. :cry: Thanks mate.
  4. jag-engr
    jag-engr Semper Bufo!
    There's a nice picture of how pop rivets work towards the bottom of this page.
    If you're wanting a hole through the fastener, some Chicago screws are hollow in the middle. Alternately, you could use a D-shackle or bow shackle to achieve similar results if you intend to use the split ring for leverage.
    Check out the first link in my signature line for more ideas.
  5. Gnarly
    Gnarly Loaded Pockets
    jag-engr beat me to it!
    He is our Resident Keyring Guru, and he has rightfully EARNED that title thru research.
  6. Smith28
    Thanks guys. Looks like I'm not going to be able to get as compact as the rivet idea. Sad times.
    Edit, Hang on!!!!!!!!!!!!! I've just figured it out.....
    Surely the hollow version of a pop rivet, is an eyelet. ??
    :frantic:
  7. Cobra 6 Actual
    Cobra 6 Actual Loaded Pockets
  8. Smith28
    Just to document my progress with this, have found that pretty much no one makes eyelets with a long enough barrel to go through the keys (I have 3 regular width Yale type keys) and then have enough length to fold back down and secure in place.
    I've contacted a couple of companies to see if they can do something for me. What a mission.
  9. batteur
    batteur Loaded Pockets
    How about simply shortening a tube (brass, aluminium, …) with fitting diameter and flaring the ends?
  10. vegassprky
    vegassprky Loaded Circuits
  11. kertap75
    kertap75 EDC Junkie!!!!!
    I saw brass bushings at TSC last time I was there. Seem like they would work for what you want. A brass tube with one end already flattened for you. Just cut to size, put your keys on, and flare the end so they won't come off
    Sent from my SCH-I405 using Tapatalk 2
  12. Smith28
    I get what you guys are saying, but I can neither find any such items lying around, nor have I been able to find any good options in the UK. I think one problem is the specific dimensions I'm after and the fact that a lot of the time you can't buy this stuff in TINY amounts like I need.
    Nevertheless, thank you for all the interesting ideas, 'tis appreciated.
    I don't really see any point in reinventing the wheel, when eyelets are pretty much what I would be trying to replicate. I'm not going to devote lots of research (and £££) in other Heath Robinson options until I've exhausted that route, if that time comes then I'll happily get the drawing board out. If you see what I mean. :confused:
  13. shmook
    shmook Loaded Pockets
    Just curious, but why do you need the hole in the middle?
    Edit, if you don't, I could possibly send you some rivets. We use them every day, and have different sizes in, to save you buying a whole box!
  14. boyo17
    boyo17 EDC Junkie!!!!!
    The pin remaining in the centre of a pop rivet can easily be tapped out with the snapped off bit of pin
  15. Smith28
    I want to be able to put a split ring through them so I can still keep them on a keychain. I've never actually used rivets before but I think they naturally wouldn't work with a keychain. Thanks for the offer man, I may PM you and see what you can do, of course I would reimburse you for your trouble.
    Really? Wouldn't that mean the rivet would come apart? If not, then that would be brilliant.
  16. shmook
    No reimbursement needed, I'll just bung some in the post, but the hole won't take a split ring, it's probably less than 1mm wide.
    The rivets don't come apart. The steel 'tail' has a domed head, which pulls and squashes the aluminium rivet I to place, and then the tail snaps, leaving he Ali squashed into position. The domed end of the tail is then redundant and left in, but as said, can be tapped out :)
  17. Fabregas485
    Fabregas485 Loaded Pockets
    Smith I have a solution for you, but it requires drilling a new hole in 1 of your keys. If you drill a hole 10mm or so under the current hole and them rivet all the keys, plus the key with the hole you just drilled. This will give you the effect of 1 keys riding higher than the others so that a split ring can be attached. If I need to I will draw it.
    EDIT: Thought I would draw it anyway. The red key is the one with the new hole, so rides higher.
    Gnarly and TECENG like this.
  18. amacman
    amacman Loaded Pockets
    What about steel brake line? Its sold buy the foot at auto parts store, and they'll also have the flaring tool.
    ac7ss likes this.
  19. Smith28
    Thanks Shmook that is very kind, but from the second part of your post, I think my problem has been solved! So basically, it's like an eyelet, just with that redundant piece left in - that is however removable. Perfect!
    I now have a rivet gun with assorted rivets in the post as well as a Draper set of 4 files on their way to me. I'll dig the hack saw out and find some washers and soon I should have a finished product!
    Thanks for all the great ideas, especially Fabregas, what a coincidence, I was actually thinking of pretty much that exact same thought today, still an option if I need a separate hole for rotation and split ring.
  20. vegassprky
    Pics when done please?
