recommend me a light based on survey
Discussion in 'Flashlights & Other Illumination Devices' started by Donald Morton, Aug 20, 2020.
  1. Donald Morton
    Donald Morton Loaded Pockets
    I'm stuck in the 80's with my big, D Cell Maglite and I desperately need an upgrade!
    I've filled out the sticky New Flashlight Survey (below) so you can get a better idea of what I'd like.
    Please make your recommendations!
    Thanks,
    Don
    maintenance around the house and garage
    [ ] $1-15
    [x ] $15-30
    [x $40-60
    [ ] $80-$120
    [ ] I have no limit!
    4) Format:
    PART A
    [x ] I want a flashlight.
    [ ] I want a headlamp.
    [ ] I want a lantern.
    PART B
    Length:
    [x ] 2-4 inches. (Pocket carry)
    PART C
    Width:
    [ ] I prefer a long narrow light.
    [x ] I prefer a short wide light.
    [ ] Doesn't matter.
    5) What kind of "bulb".
    [ ] LED - more rugged, unlikely to burn out in your lifetime, less accurate color rendition, in general less output but more efficient (longer runtimes)
    [x ] HID - like new car headlights in color, very, very bright, can be had in lights as small as a Mag 2 D cell but generally larger spotlight sized lights, no dimming turns off when battery depletes
    [x ] I want common Alkaline batteries. (AA, AAA, C, D)
    [ ] I want lithium batteries. (coin cells, CR123, AAA, AA...)
    [ ] I want to walk around a generally paved area. (15-20 lumens)
    [x ] I want to walk unpaved trails. (40 lumens)
    [ ] I want to light an entire campground or dazzle an intruder. (100+ lumens)
    Throw (distance)----------------------|--------------x--------Flood/close-up
    [x ] 20 min. (I want the brightest light for brief periods)
    [ ] 60-240 min. (1-2 hours)
    [ ] 240-360 min. (4-6 hours)
    [ ] Slightly Important (Walks around the neighborhood.)
    [x ] Very Important (Camping, Backpacking, Car Glove-box.)
    11) Switch Type:
    [ ] I don't care.
    [x ] clickie switch. (Stays on until pressed again.)
    [ ] rotating switch
    12) Switch Location:
    [ ] I don't care.
    [x ] I want a push switch on the back end of the body.
    [ ] I want a remote control.
    [x ] A simple on-off is fine for me.
    [ ] I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
    [ ] I want S.O.S. flashing
    [x ] I don't care.
  2. SOS24
    SOS24 Loaded Pockets
    I don’t know any HID lights, but as far as a good LED flashlight that I think meets most your other criteria, I would recommend looking at the Lumitop Tool AA or AAA, Streamlight 1L-1AA, or EagleTac D25A.
  3. neo71665
    neo71665 Loaded Pockets
    Flashlight tech has generally embraced LEDs and given up on anything else. The comments on leds having less accurate color rendition and less output but more efficient are outdated.
    Moshe ben David likes this.
  4. Donald Morton
    will check out those recs, SOS24
    SOS24 likes this.
  5. Donald Morton
    good to know, neo.
  6. Moshe ben David
    I just looked through that questionnaire.... for a simple tail-light clicks, I'm a huge fan of Streamlight. But get the basic models if you don't want to fiddle with 'just right' clicking to progress through varied lumen outputs...
    For portability, a long time favorite of mine and many on here has been the simple basic Streamlight Microstream. Uses a single AAA cell. Output around 40 lumens. Single click tail switch. Comes with a clip that can just clip in a pocket or could easily clip on the brim of say a ball-cap; no fiddling, just slip it on....
    Note: they do have a 'USB rechargeable' version of the Microstream. It has a multifunction tail switch. Which I've found to be not so useful. The USB version 'can' run with a AAA alkaline battery; but why pay extra for the functions you don't need nor want?
    My second favorite from the same company is the Streamlight Stylus Pro. Basically a 'big brother' to the Microstream; takes 2 AAA batteries. About the size of most pocket pens. Noticeable brighter than the Microstream although for me for most situations either works just fine. Same sort of tail switch as the Microstream.
    Neither is high priced. Last pricing I saw say on Amazon was about $17 for the basic Microstream; $20 for the Stylus Pro. Both have had a praised track record on these Forums and elsewhere....
    Am Yisrael Chai!
  7. victograph
    victograph Loaded Pockets
    Moshe ben David is a wise sage with much experience.
    #7 victograph, Aug 20, 2020
    Paladin0328 and Moshe ben David like this.
  8. Donald Morton
    Moshe Ben David,
    Thanks for your thoughts and recommendations. I'm adding them to the "research" list.
  9. Donald Morton
    Since I've "saved" soooo much $$$ over the years by sticking to my '80s maglite, I decided to splurge and purchased the Streamlight 1L-1AA. Should be here today.
    Thanks for taking the time to respond to my query!
    Don
    Moshe ben David and SOS24 like this.
  10. SOS24
    Glad we were able to give some suggestions and you found something. Interested in hearing your thoughts after you get an opportunity to use it.
  11. Moshe ben David
    Not really. 'If' I were an emotional sort, maybe I'd be blushing? Naaah! ;)
    Am Yisrael Chai!
  12. Donald Morton
    Amazon dropped off the Streamlight a couple of hours ago. First impression? BRIGHT!! Just what I was after, so that's a win. I really dig the look of the flashlight and it fits really well in hand. I've changed the factory default setup and gone with just the Hi and Low setting since I don't see any need for the strobe. The push button is stiff, perhaps because it's a quality component or just new, but that's not an issue, just an observation.
    All in all, really happy with it and you all saved me mega hours of reading reviews and going through analysis paralysis!
  13. CSG
    CSG Loaded Pockets
    While I didn't keep the one I bought (it's an anatomy thing with shrouded tail buttons for me), it's a really cool light and can even be operated with AAA batteries although Streamlight does not acknowledge that.
    #13 CSG, Aug 21, 2020
  14. SOS24
    Glad you’re liking it.
    #14 SOS24, Aug 21, 2020
  15. kukla
    kukla Loaded Pockets
    holy _ _ _ _!
  16. Donald Morton
    48 hr. update:
    Using my new flashlight for a total of less than 4 hours runtime on High beam, it all of a sudden stopped working on High beam. Both the Low beam and strobe mode worked, however. After a brief flurry of voicing some choice word phrases, I calmed down enough to swap out the CR123A battery with a AA, just to see what might happen. Bingo, High beam back in business!
    But seeing as the CR123A battery (Streamlight brand) has a "good until date" of 2028, I'm disappointed in how fast it drained its capacity to run the High beam. Does this seem normal to you guys?
  17. twin63
    twin63 Loaded Pockets
    Streamlight lists 1.3 hours of runtime on high with a CR123, so it sounds right. A lithium AA (Energizer L91) will get you more runtime on high, but output will only be 150lm vs. 350lm. Unfortunately, if you need higher output for longer periods of time, you may need to look into a light that can run on rechargeable lithium ion batteries.
  18. SOS24
    Unfortunately, as twin63 said, it does seem about right. The runtime on high of many lights is not that long.
  19. Donald Morton
    Wish I had thought of checking the manufacturers specs, duh :banghead:
  20. EZDog
    I am a little confused about this?
    You said you wanted 40 lumens for 20 minutes and you got a lot more output for more than 10 times your hoped for runtime right?
    So why the let down exactly?
    If you had chosen a 40 lumen light you might well get a lot more runtime.
    And of course reading the specs before buying should give you an idea of what to expect too.
