Pill Fob Questions
Discussion in 'Other Carrying Devices' started by lancenat, Aug 24, 2018.
  1. lancenat
    lancenat Empty Pockets
    Hey all,
    I'll post my EDC daily carry soon as it's part of my question but for those who do carry a pill fob, do you guys have separate ones for pills?
    I'm right now using a altoid tin to store a little ziploc bag of advil, melatonin and gravol. Different shapes and sizes so easy to pick out but if swapping over to pill fobs do the pills for the most part stack on top of each other?
    Any recommended 'cheap' brands so I can give it a try? Or are there any longer ones that has like 3 compartments similar to protein shakers (only thing I can think of as an example haha) where you can stake your pills, protein powder, then the actual bottle part?
    Appreciate the help! :)
    Sent from my BBB100-1 using Tapatalk
  2. karlito
    karlito Loaded Pockets
    While I don't use a pill for for pills (earplugs), I would simply stack them with maybe some tissue between the different types.
    You can get various sizes off of eBay (from China) for nickels a piece to try and see what works best for you.
    sent from your mamma's house
  3. lancenat
    Thanks! That's actually a solid idea; do you use disposable ear plugs or do you have the nicer ones?
  4. karlito
    The nicer one, I really dislike the idea of disposable everything. I've seen the exact same fobs at stores for literally 5x the cost of the eBay ones.
    ProjeKtWEREWOLF likes this.
  5. assassin10000
    assassin10000 Loaded Pockets
    Plenty of ebay ones that are cheap. County comm has a bunch of items that could be used and IIRC they have a 2 compartment one. On the expensive side there are the Cogent pillpots.
    If you only need to store a couple of each and want a very small format you could use the DQG waterproof capsule and buy extra extensions that work with them to hold as many different types as you wanted. They sell thru hole and non-thru hole extensions. You can lego as many together as you want if you want to store more of something.
    I currently use one to hold both a pair of earplugs as well as 2 aleeve in a second compartment for the base using the cap from their lighter.
    #5 assassin10000, Aug 28, 2018
    garza and Nick4305 like this.
  6. lancenat
    Thanks, those look interesting. I'll take a look into those!
  7. Moshe ben David
    Figured I'd jump in. I have a very generic SS screw top fob that I picked up years ago at Walmart in the section of the store with other cheap camping etc items. It has an o-ring so seals pretty tight. Small diameter so only really works with things like gel-caps but can hold a 'typical' dosage of two caps end to end. No idea what I paid for it but I will bet it was cheaper than :censored: near anything else of this genre... Works for me when I need it. Which these days I do...!
  8. lancenat
    Thanks Mosche! Didn't know they sold them there! Nice to be able to actually see them before just jumping the gun on trials. Will definitely take a look at them!
  9. swedishelite22
    swedishelite22 Loaded Pockets
    When I looked into a fob for pills everything I found at local shops were too big for easy pocket carry IMO. There were also a lot of comments on cheaper ones that they didn't hold out water/moisture and/or left a taste on the meds.
    In the end I bit the bullet and bought one of these...
    GUS Original Pill Fob, Made in USA, Stainless Steel Keychain Pill Holder, AAA Battery Holder https://www.amazon.com/dp/B00MY9JR0E/ref=cm_sw_r_cp_apa_Iy0HBbSXY8FET
    They come in 3-4 sizes depending on which you want and can be used for other purposes obviously. I get 5 pills in it (3 of which being Tylenol capsule size). I can take pics of you'd like.
    I've had mine for ~3-4 months and can't complain.
  10. BillSXT2002
    BillSXT2002 Loaded Pockets
    I agree with checking out countycomm. They have a variety of sizes, and you can get some string to loop through the holes to keep them together. You can even get colors to color code your capsules.
    Sent from my SM-G965U using Tapatalk
  11. lancenat
    Thanks guys, unfortunately, I'm located in Canada so some places don't ship there. But been looking at the ones with multiple compartments but we'll see if I can pick up one that's not like $55 for one.
  12. SOS24
    SOS24 Loaded Pockets
    I just use an old chapstick tube that I cut the screw post off. It isn’t waterproof or segmented into multiple compartments but it works for me just to hold together and prevent crushing. I carry in a pocket organizer with some other items.
    If you wanted to make a keychain, a mini eye hook screwed into the base with some glue or epoxy for extra hold.
    karlito likes this.
  13. lancenat
    So I sprang on two different sized ones from Aliexpress - will definitely try it out and see how I feel about it. Thanks for all the tips/suggestions!
  14. TNRonin
    TNRonin Loaded Pockets
    I use county comm small boxes or a Tylenol travel tube. I'm actually leaning towards the travel tube as the county comm box has opened on me.
    Sent from my SM-T280 using Tapatalk
  15. labrat
    labrat Loaded Pockets
    A thread from long time ago!
    But I just use half of a lens carrier, the ones you put your lenses in when not using them.
    They are one for Left and one for Right side lenses, I cut them so I could use only one of the sides, enough room for my necessary medicine supply for one day.
    They are air and water tight, no smell or taste, goes deep down in the bottom of the watch pocket on my jeans.
    Perfect for my need!
    #15 labrat, Feb 26, 2020
    post tenebras, karlito and RoadWizard like this.
  16. echo victor
    labrat,
    That's a good idea. My wife and daughter use contacts, so I make sure that we have enough solution on-hand. I buy a 2-bottle box at my local big-box store and each box comes with 2 plastic lens holders. I have a bag at home with what seems like at least a hundred of those cases. LOL I don't know what to do with them and have taken to recycling some. The idea is that one is supposed to change the lens case with each new bottle of solution. I just can't convince the women in my home to do that.
    garza and RoadWizard like this.
  17. neo71665
    neo71665 Loaded Pockets
  18. RoadWizard
    RoadWizard Loaded Pockets
    I also use the contact lens cases that come with Opti free cleaner, have 2 compartments with white and green lids, put am meds in one, pm meds in other.
    echo victor likes this.
  19. Jean
    Jean Loaded Pockets
    I would recommend opening your emergency pill fobs occasionally. I wanted to get some meds after a long flight delay - no go. Took soft jawed pliers to get it open at home. This was a mid sized countrycomm open, had been closed for at least two years.
  20. Iron Brew
    Iron Brew Loaded Pockets
    I use the battery containers from county comm.
    Tough and waterproof
