Is there a grip that good grip kinda like pop socket that will work on the magpul bump case. (I think it has some texture in it) Also is there good grip on the magpul bump case because I just ordered it Sent from my iPhone using Tapatalk
Designed for the iPhone silicone cases, but you might want to see if the Popsocket Slide will work with the Magpul Bump. ATB, Sam
The grip in your hand is pretty ok since it has raised lines on the back and around the side, but it's more of a hard plastic than a grippy rubber, so it can slide around on slippery surfaces. Regardless I've used one for a long time now over multiple phones. I just ordered a Cat Tongue grip? from Amazon for it, it's basically a textured/rubbery sticker that goes on the back. Obviously isn't 100% flat on the case due to the aforementioned raised lines, but is sticking ok so far. I do worry about how long it'll last stuck on though, as there is probably a good possibility that the edges of the sticker catches on something - pocket, pouch, etc. at some point.
