Need some help on choosing an EDC light
Discussion in 'Flashlights & Other Illumination Devices' started by eogahn, Mar 17, 2010.
  1. eogahn
    eogahn Loaded Pockets
    Ok, so I'm new to flashlights, but i've been carrying a AAA LED maglite recently. Its the nicest flashlight I've had but it leaves alot to be desired. I've been looking at a lot of lights, and the PD30+ and the LD20+. Any help would be much appreciated!! :) I used the form provided by the forum, so I think I answered any question you might have but sorry if I didnt give enough info! Thank you
    I will be using this light as my EDC light. It would be nice for it to fit on my belt but at the moment I carry the Maxpedition lunada everywhere with me, so it will likely be kept in there. I will also be going camping quite a bit soon and would like for it to be suitable for camp needs. I do live in new england as well... so it will probably be getting a wide range of weather use.
    [x] I will be mail-ordering or buying online, so this doesn't matter.
    [ ] I am in _______(country) and __________(state/providence).
    3) Price Range: An easy question, but you may change your mind after answering the rest!
    [ ] $1-15
    [ ] $15-30
    [x] $40-60
    [ ] $80-$120
    [ ] I have no limit!
    4) Format:
    PART A
    [x] I want a flashlight.
    [ ] I want a headlamp.
    [ ] I want a lantern.
    PART B
    Length:
    [ ] 2-4 inches. (Pocket carry)
    [x] 4-9 inches. (Holster carry)
    PART C
    Width:
    [ ] I prefer a long narrow light.
    [x] Doesn't matter.
    PART D
    Weight:
    [ ] Very light, can't tell it's there.
    [ ] Light, no heavier than a few keys or a small car remote.
    [x] Medium light, about the weight of a AAA MiniMag
    [x] Medium, slightly heavier than a AA MiniMag
    [ ] Heavy Medium, can of Coke
    [ ] Heavy, PDA or small digital camera
    5) What kind of "bulb".
    [x] LED - more rugged, unlikely to burn out in your lifetime, less accurate color rendition, in general less output but more efficient (longer runtimes)
    [ ] I want common Alkaline batteries. (AA, AAA, C, D)
    [x] I want lithium batteries. (coin cells, CR123, AAA, AA...)
    [x] I want a rechargeable system. (an investment, but best for everyday use)
    [x] I want to read a map, find a light switch/keyhole, or get around the house at w/o disturbing anyone. (5-10 lumens)
    [x] I want to walk around a generally paved area. (15-20 lumens)
    [x] I want to walk unpaved trails. (40 lumens)
    [x] I want to do Caving or Search & Rescue operations. (60+ lumens)
    [x] I want to light an entire campground or dazzle an intruder. (100+ lumens)
    Throw (distance)-----------------x----|----------------------Flood/close-up
    [x] 60-240 min. (1-2 hours)
    [x] 240-360 min. (4-6 hours)
    [ ] Slightly Important (Walks around the neighborhood.)
    [x] Very Important (Camping, Backpacking, Car Glove-box.)
    11) Switch Type:
    [ ] I don't care.
    [x] clickie switch. (Stays on until pressed again.)
    [x] momentary switch. (Only stays on while held down.)
    [ ] rotating switch
    12) Switch Location:
    [ ] I don't care.
    [x] I want a push or sliding switch on the body near the head.
    [x] I want a push switch on the back end of the body.
    [ ] I want a remote control.
    [ ] A simple on-off is fine for me.
    [ ] I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
    [x] I want multiple light levels. (some lights have 5-16 light levels.)
    [x] I want a strobe mode. (blinks to show location.)
    [x] I want S.O.S. flashing
    [x] I don't care.
    [x] Waterproof – how deep: _Not too big of a deal, but I could drop it in the water by accident____________
    [x] Corrosion resistant or hard-anodized finish
    [x] Belt/Jacket clip
    [x] Holster
    [x] Wrist/Neck Lanyard
  2. eogahn
    Ohhhhhh I forgot to mention. I noticed alot of people start with a base flashlight and then modify it with aftermarket parts, etc... I think thats a great idea and if a custom light would better fit my needs I would love to do it! Its always better when you have your own unique tools.
  3. jsmitty1967
    jsmitty1967 Go Big Blue
  4. eogahn
    Ok awesome, I'll look thru the line. Yeah the side switch isn't too big of a deal, it would just be nice, a bottom switch is plenty good. Thanks!
  5. PeaceOfMind
    PeaceOfMind Loaded Pockets
    I'd recommend you consider the Quark series from 4Sevens (see 4Sevens.com). They come in lots of different battery configurations, so you can pick the best size for you (AA, 2xAA, CR123, 2xCR123). If you want more throw, you can go for the Quark Turbo line. I'm a big fan of the UI of the Quark Tactical line (program two modes). The regular Quark line lets you cycle through the modes using a forward clicky. Great quality lights, reasonably priced and lots of different options using cutting edge LEDs.
    EDIT: jsmitty beat me to it
  6. jsmitty1967
    Nothing wrong with a +1! :)
  7. rasi
    rasi Loaded Pockets
    If you want to go the custom way: McGizmo Haiku XP-G. With 2xAA body if you prefer 4"+ length.
  8. jda
    jda Loaded Pockets
    love my 4sevens aa^2 quark
    for $50 I wont be too sad if i lost it eather
    (yeah it would suck it wouldnt be the end of the world)
  9. lonewolfranger
    lonewolfranger Loaded Pockets
    A bit pricer, but the Surefire Outdoorsman series speaks for itself. I walk my dog with an L2 Lumimax. 60 lumens for 11 hrs. on 2 lithium cr123.
    Surefire will replace the head if it ever goes out. They already sent me a new tailcap because I wore the original out over a two year period, for free. One phone call. Can't beat the quality or customer service. Thumbs up in my book!
  10. eogahn
    thanks guys! I will definitely look into all your suggestions, you guys know a lot more than I do about these ;)
  11. eogahn
  12. Skipperbrown
    Skipperbrown Loaded Pockets
    Don't forget you're picking a light w/ 123 cells which are much more expensive than AA and harder to find. There are advantages to both, but keep cost and availability in mind. You can get AA cells at most quicky marts and all over the world.
  13. marsos52
    marsos52 Loaded Pockets
    looks like light gives you everything you outlined ....nothing better than i high quality torch
    and there are good deals on cr123's try battery juction the site is down now but coming back soon
