Need a recommendation
Discussion in 'Flashlights & Other Illumination Devices' started by babarog, Oct 10, 2019.
  1. babarog
    babarog Empty Pockets
    Lighting up sidewalks and keyholes while moving around city maybe some warehouse areas. Location Oslo/Bergen Norway
    [X] I will be mail-ordering or buying online, so this doesn't matter.
    [If there is a shop in Norway] I am in Norway / Oslo.
    [X] I have no limit but would not like to waste money if not needed!
    4) Format:
    PART A
    [X I want a flashlight that could be used as a bike light aswell.
    PART B
    Length:
    [ ] 2-4 inches. (Pocket carry)
    PART C
    Width:
    [ ] Doesn't matter.
    PART D
    Weight:
    [X] Very light, can't tell it's there.
    [X] Medium, slightly heavier than a AA MiniMag
    5) What kind of "bulb".
    [X] Don't care, just want the best fit for my needs. HID preferably
    6) What batteries do you want to use?
    Dont care. Whats the most acessible system
    7) How much light do you want?
    [X] I want to walk unpaved trails. (40 lumens)
    [X] I want to do Caving or Search & Rescue operations. (60+ lumens)
    [X] I want to light an entire campground or dazzle an intruder. (100+ lumens)
    X Flood/close-up
    9) Runtime:
    [ ] 60-240 min. (1-2 hours)
    [X] Critical (Police, Fire, Search & Rescue, Self-defense, Survival.) MUST BE WATERPROOF
    11) Switch Type:
    [ ] clickie switch. (Stays on until pressed again.)
    12) Switch Location:
    [X] I don't care.
    [X] A simple on-off is fine for me.
    14) Is it important whether the body is metal or plastic/composite?
    [X] I don't care.
    15) Special Needs:
    [ ] Red (night vision preserving) filter / could be nice but not nececery
    [X] Waterproof – how deep: 50-100m
    [X] Corrosion resistant or hard-anodized finish
  2. aicolainen
    aicolainen Loaded Pockets
    @babarog
    Fellow Norwegian, for just the occasional need to find your way around in the dark, I can't recommend a simple AAA light enough. They disappear in the pocket, yet you can find very potent little lights with 100+ lumens and high CRI emitters.
    I haven't tried a ton of different AAA lights, but I'am quite satisfied with all the ones I have from Maratac, Lumintop, Olight and Drop. I tend to gravitate towards Hi CRI / Nichia flaslights and the ones with cooler color temperatures sees very little use after a while.
    CountyComm / Maratac ships to Norway now, and if my last order is anything to go by, they make very creative customs labels (to your advantage), so you could now get something like this at an acceptable price:
    https://countycomm.com/collections/aaa-flashlights/products/aluminium-anodized-aaa-flashlight-by-maratac-rev-3
    Drop.com generally has some of the lowest shipping fees to Norway, so if you find something there, you could get away with a very acceptable total cost.
    This one is in their in-stock products, that you can buy at any time:
    https://drop.com/buy/massdrop-aluminum-aaa-flashlight
    I have the brass version:
    https://drop.com/buy/massdrop-brass-aaa-pocket-flashlight/details#details
    There is also a bunch of small USB rechargeable lights out there. I don't have any, but the Rovyvon Aurora is one I have considered many times.
    It comes in many configurations, but for me, the titanium version would be hard to resist if I was getting one:
    https://www.rovyvon.com/products/a4?variant=19515899773031
    Good luck
    babarog likes this.
  3. sonderdienste
    sonderdienste Loaded Pockets
    I carry an EagTac D25A Clicky Mk II all the time. It virtually disappears in my jeans' front pocket but is always ready. Can't recommend it enough. :)
    At first I ran it on AA Eneloops but when I found some good quality 14500 Li-Ion cells that fit in diameter, I switched to those because they give you much more light. I keep the light's head screwed tight which basically gives you simple on/off operation, just what I need for 99% of applications.
    I've EDC'd RCR123 and 18650 lights in belt holsters and in-pocket but the D25A just has the right shape so you forget it's there, while still providing significantly more power than an AAA light.
    Another feature that made me select this specific AA light is the permanently attached pocket clip, none of that snap-on rubbish. :D
    Oh and I got the Nichia high-CRI version. A little less lumens than the other options but I love the natural tint.
    Edit: While looking at the Massdrop AAA light, I noticed another reason my D25A disappears so neatly inside a pocket is the "deep carry" type clip.
    babarog likes this.
  4. SOS24
    SOS24 Loaded Pockets
    There are lots of lights that will meet your desired characteristics.
    For convenience with batteries, a AA is probably your best bet, although AAA would also work. The EagleTac D25a is a good light. I also like Fenix LD12 which is a little bigger.
    For bicycle riding aspect, unless this is your primary use, I would look for a flashlight you like then purchase a adjustable bracket for bicycle use such as a silicone band
    babarog and twin63 like this.
  5. turbo6
    turbo6 Loaded Pockets
    I think a single 18650 light would be your best bet. Plenty of length to affix to a bicycle and more power and run time than a smaller AA type light.
    For something robust and durable check out Fenix, for something more budget friendly maybe Wowtac.
