Narrow Rechargable Keychain Light?
Discussion in 'Flashlights & Other Illumination Devices' started by thegrouch314, Nov 1, 2018.
  1. thegrouch314
    thegrouch314 Loaded Pockets
    I'm after a small, narrow flashlight for a keychain. Diameter is my main limit, ideally under 10mm. Length matters less so I can go up to 100mm. Aside from that, I'm not too bothered by anything else. I'd preferred a bright/dim setting but it's not super important.
    [ X] I will be mail-ordering or buying online, so this doesn't matter.
    [ ] I am in _______(country) and __________(state/providence).
    [ X] $1-15
    [ X] $15-30
    [ ] $40-60
    [ ] $80-$120
    [ ] I have no limit!
    4) Format:
    PART A
    [ X] I want a flashlight.
    [ ] I want a headlamp.
    [ ] I want a lantern.
    PART B
    Length:
    [ X] 1-2 inches. (Keychain sized)
    [ ] 2-4 inches. (Pocket carry)
    PART C
    Width:
    [ X] I prefer a long narrow light.
    [ ] Doesn't matter.
    PART D
    Weight:
    [ ] Very light, can't tell it's there.
    [X ] Light, no heavier than a few keys or a small car remote.
    [ X] Medium light, about the weight of a AAA MiniMag
    [ ] Medium, slightly heavier than a AA MiniMag
    [ ] Heavy Medium, can of Coke
    [ ] Heavy, PDA or small digital camera
    5) What kind of "bulb".
    [ ] LED - more rugged, unlikely to burn out in your lifetime, less accurate color rendition, in general less output but more efficient (longer runtimes)
    [X ] Don't care, just want the best fit for my needs.
    [ ] I want common Alkaline batteries. (AA, AAA, C, D)
    [ ] I want lithium batteries. (coin cells, CR123, AAA, AA...)
    [ X] I want a rechargeable system. (an investment, but best for everyday use)
    [ X] I want to walk around a generally paved area. (15-20 lumens)
    [ ] I want to walk unpaved trails. (40 lumens)
    [ ] I want to light an entire campground or dazzle an intruder. (100+ lumens)
    Throw (distance)----------------------|---------X-------------Flood/close-up
    [ ] 60-240 min. (1-2 hours)
    [ X] 240-360 min. (4-6 hours)
    [ ] Slightly Important (Walks around the neighborhood.)
    [X ] Very Important (Camping, Backpacking, Car Glove-box.)
    11) Switch Type:
    [ ] I don't care.
    [ X] clickie switch. (Stays on until pressed again.)
    [ ] rotating switch
    12) Switch Location:
    [ X] I don't care.
    [ ] I want a push switch on the back end of the body.
    [ ] I want a remote control.
    [ ] A simple on-off is fine for me.
    [ X] I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
    [ ] I want S.O.S. flashing
    [ X] I don't care.
    [ ] Waterproof – how deep: _____________
    [ ] Belt/Jacket clip
    [ ] Holster
    [ ] Wrist/Neck Lanyard
    (edited for clarity 1/11/18)
    #1 thegrouch314, Nov 1, 2018
  2. steeps
    steeps Loaded Pockets
  3. SOS24
    SOS24 Loaded Pockets
    I’m not sure you are going to find a rechargeable at less than 10mm diameter. Both 10180 and AAA batteries by themselves are 10mm. My favorite keychain light and one of the smallest I’ve seen that is rechargeable is the DQG Hobi+, but that is still 12.8mmin diameter. Other companies make similar but all of them I know are about 12-14mm (Fenix UC02, Maratac Peanut LED, MecArmy X2S).
    To get below 10mm, I think you would have to go with a light like the Streamlight Nano, Pelican Progear 1810C, or something similar that runs LR41 or similar coin cell. Those tend to be low lumen single output and non-rechargeable.
    Someone else may be able to come up with something else.
    #3 SOS24, Nov 1, 2018
    smokingfish likes this.
  4. Moshe ben David
    Nitecore Tube or one of its design descendants maybe? Definitely rechargeable, lightweight, and compact.
    Blackbeagle likes this.
  5. assassin10000
    assassin10000 Loaded Pockets
    DItto, probably not going to find a rechargeable at or near 10mm and under.
    I carry a DQG Hobi+ on my keychain as it was the smallest (dia) rechargeable I could find. It has 3 levels. It's a backup as I carry flashlights in my vehicles as well.
    If 2 levels are all you need you could also get a Jetbeam Mini-1. I like the older version with no clip (key or neck chain). It uses a simple 2 level switch that engages the 2nd level when further tightened. I had one but decided to go with the Hobi+ as it IS the smaller of the two.
    #5 assassin10000, Nov 2, 2018
  6. thegrouch314
    Thanks for the advice everyone
    I doubted there was a rechargeable light that narrow so I'm probably going to go with the streamlight nano
