Makarov Pistol - Concealed carry fun in a Combloc surplus package
Discussion in 'Gear Reviews' started by Lee1959, Aug 30, 2006.
  1. Lee1959
    Lee1959 Empty Pockets
    The Makarov is a Russian design that came out after WWII. The designer obviously had seen a Walther PP a time or two as the pistol has a very strong resemblance to that firearm. It is however a very different pistol.
    It fires the 9X18 or 9MM Makarov which is an intermediate round which falls roughly between the .380 Acp and 9X19 or 9MM Luger. It is a straight blowback pistol with double and single action capablities. The Safety is a decocker also (which takes some getting used to if it is your first decoker, watching that hammer drop is a bit spooky).
    Conversion barrels are available in .380 ACP and the same magazine may be used. Capacity in either caliber is 8 + 1, the exception being some Russian models which use a double stack 10 or 12 round magazine.
    The pistols were made in 4 countries and are imported as surplus. The most prevelent found in recent years are the "Bulgies" or those made in Bulgaria. FEG makes a pistol that fires the 9x18 but it is not a Mak, and not the same quality from what I have heard. Prices are generally reasonable for Makarovs so why go with an imitation anyways. I paid $150 for my pistol with 4 magazines included.
    Takedown is easy, remove magazine and make sure pistol is empty. Pull downward on the front of the triggerguard, hold it with your finger, and pull back and upwards on the slide, removing it. This gives you access for cleaning and changing recoil springs, which I highly recommend as they are used pistols. Since they are blowback this means a weak spring can cause damage to the slide and frame in recoil that is not soaked up by the spring. Springs are easily obtained from Makarov.com.
    Replace the slide in the opposite direction, holding down on the triggerguard, it will need to be wriggled a bit sometimes to pop on, watch your fingers they can get pinched.
    Type: Double/Single action
    System of Operation: Blowback
    Safety: Hammer block, slide lock, decocking
    Caliber: 9x18mm (9mm Makarov)
    Capacity: 8+1 rounds (10 + 1 in the few Russian double stack magazine models)
    Sights: Fixed blade front, dovetailed u-notch rear, drift adjustable
    Length: 6.34"
    Weight (loaded): 1.71 pounds
    Barrel: fixed (need barrel press to replace barrel or change caliber)
    Magazine release: heel
    Manufacturing Countries: Russia, East Germany, China and Bulgaria (Hungarian FEGs are NOT Makarovs, they are similar and fire the same cartridge but they are not the same gun)
    Overall impressions:
    I first got the Makarov several years ago, around the time of Y2K when I decided to pick up my CCW permit and wanted a smaller pistol than my .45 to carry at times. For $150 including 4 magazines, and a box of ammuntion, I could hardly pass it up. It is a handsome pistol, very nicely finished and blued. Mine is the East German variant which are reputed to be the best finished. Russians, Chinese, and Bulgies are a bit rougher in finish but shoot just the same.
    My first impression when I picked it up was WOW, for a smaller pistol it is rather heavy, which it is. However, that weight soaks up any recoil and makes it perhaps the sweetest shooting pistol I have ever shot. I used it sight unseen(unshot) for my CCW class and scored the highest in the class, the instructor even went out the next day and bought one for himself after shooting mine. 100 rounds were put through the pistol the first night I owned it and I was very impressed.
    Right from the first magazine I found out that I could rapid fire this pistol as fast as I could pull the trigger and put all rounds in a nice tight group. Recoil with the relatively heavy weight, and the heavy recoil spring is practically non-existant.
    The only problem I have had with it in almost 6 years now was the slide stop failed to work upon the last round fired when I first got it. I finally figured this problem out to be the magazines were dirty, and the springs needed to be changed. I took the magazines apart, cleaned them well, and replaced the springs and the recoil spring with replacements from Makarov.com. I went with the extra power springs, and it is definitly noticible, pulling back the slide takes a bit of work and thumbing in that last round is a chore, the available magazine loading tool helps a lot.
    Pluses:
    It is a relatively cheap, but very reliable pistol. One of the best bangs for the buck I have encountered. The heel clip magazine release, and decocker take a bit of getting used to but work very well once you are used to them. The rubber grip fits my hand very well, I am sure others will change them though.
    It is a SHOOTER with a capital S, I have yet to have a failure to feed or fire in many types of ammunition. Shooting it is one of the more pleasant experiences. It is extremely hardy and accurate.
    The caliber is plenty stout with a decent variety of different brands and loads for this Combloc round. There are some nice hollowpoint, and frangible rounds available. It hides away nicely in either a hip holster or my behind the back holster. Replacement of things like springs, an even the firing pin are truly very easy to accomplish, making it an easy pistol to maintain.
    Minus':
    Heavy for a small caliber pistol. It is much heavier than my Kel-tec, even though they can be used in the caliber. The grips, while serviceable, look a bit cheap, especially if you get the red starred Russian grip.
    The sights are fixed, but drift adjustable, and some might think a bit small. But they are unusually well adapted and useable on this piece. I use white liquid paper on the front and outlining the rear for additional visiblity.
    Since it is surplus, and you DO NOT know how well it has been maintained, immediately replace the recoil spring and magazine springs, just to be sure you do not damage your slide, or have feeding failures. There have been reports that dry firing can break the firing pin so buying a replacement might be a good idea.
    If you buy a heavier than normal recoil spring as I did, it can make working the slide considerably stiffer, but does not throw the casing quite are far, lol.
    You have to get used to the heel clip magazine release which is a European design not found often on American firearms.
    Conclusions:
    This is one top notch defensive pistol. It is perhaps one of the best shoooters I have found. I really like this pistol and carry it often. I am planning on buying a .380 ACP barrel, "just in case".
    One article I read on the Mak called it a .38 snubnose with half again as many rounds, in a flatter faster/softer shooting package, and quite frankly, that is pretty much exactly what it is. It would be ideal for a woman also.
    These conclusions are mirrored by a VERY fanatical, dedicated group of fans that visit Makarov.com, they call themselves Makarovniks.
  2. Makarov
    Makarov Loaded Pockets
    Fanatical, I don't understand what you're talking about...
    Here's my beauty, I've got the magrelease that Makarov.com made for the Houge-grip and the +2 extension. The magrelease works great after I modified it a bit, the +2 extension sucks.
    I reaload my own ammo with cutdown 9X19mm cases. Works like a charm, unfortunaly I don't shoot it as much as I wanted. :(
    [img width=640 height=478]http://img243.imageshack.us/img243/1816/hpim0345mediumhh1.jpg[/img]
  3. gadgetjunky
    gadgetjunky Loaded Pockets
    Very good solid cheap pistols. I had an East German that had the best DA/SA trigger of ANY pistol I have ever handled (I would have loved to take it to the shot show and had it to the guys at the SIG booth and ask them why they didn't make a trigger that nice). I got stupid a few years ago and sold it off and have regretted it ever since. $150 for an EG is a good score.
  4. alwilliam
    alwilliam Loaded Pockets
    Now all you need is the rounds that were designed for use in this weapon...here is a cutaway of the russian designed 9x18. :-X
  5. gadgetjunky
    I wouldn't mind a couple of boxes of those myself. :-X
  6. stillphoto
    stillphoto Loaded Pockets
    Please do tell why that round is special... I can see that its not normal at all (as far as the slug itself), I'm somewhat of a gun noob. Well maybe not a gun noob, but certainly a cutaway round noob.
  7. GPE427
    GPE427 Empty Pockets
    It appears to be a very large chunk of STEEL inside that cutaway, that should significantly increase penetration.
  8. gadgetjunky
    In theory, but at this sort of velocity it probably doesn't really make much difference. Steel cored pistol ammo is verboten by the Feds anyway, so alas it will live as but a dream. :(
  9. webley445
    webley445 Loaded Pockets
    Actually I think the round desgn is for maximum mushrooming effect.
    They used to make .25 auto rounds with a hollow point, then a steel bb placed in the hole. It stopped the hole from getting plugged up with material, i.e. clothing, and the bb pushed in on the hole caused expansion.
    I had read about the .25 round, then finally got hold of one in an old box of ammo someone gave me. Held on to it for historical/keepsake reasons.
    The bb design also, I think, allows for FMJ round to be used for expansion.
    The hollow point hasn't been around as long as most may think. Unusual bullet designs like this one were the norm during experimental stages. I believe as early as the 60's & 70's, a common practice was to "swage" or make cuts in lead rounds, especially .38's, in a "+" pattern to make the rounds frangible if you will. Cause the round to break apart on impact.
    One old timer told me of a kit you could get that would drill a hole in the tip of LRN to make your own hollowpoints.
    This may be the fore runner of the hydra-shock round.
    Either way the Mak is a great bargain for the money. Mil-spec, and when you hold one in your hand you know it can take a little more abuse that alot of the current production models out today. the extra heft can aide in pistol whipping someone too ;D
  10. alwilliam
    ;D Current issue Hardened Steel core kevlar defeating design that has about 2 times the penatration of a standard load ball round.The russians are big into AP rounds due to the fact that 99% of euro criminals as well as the good guys all wear vests of some type.
  11. Lee1959
    Yeah it would be kewl to have a box of those just for the kewl factor, however as it has been noted they ain't exactly one of our Uncle Sam's okee dokey list items, they will have to remain a kewl notion :).
  12. alwilliam
    Pistol Ap rounds are 100% LEGAL to own,collect,buy, etc. The real problem is...If you were to be caught with a gun loaded with AP rounds you will be grilled over a very hot flame or you ever had to use these rounds and they were found to be AP....their is a added mandatory minimum charge on top of what ever other charges you may have from your action,and if your action was 100% legal you will still be looked at very hard.A VERY BAD IDEA TO CARRY AP PISTOL ROUNDS,but very fun to own in the privacy of your home.
    If you are NOT a (FFL) licensee under the Gun Control Act (an individual):
    It is:
    ok to OWN AP ammo
    ok to SELL AP ammo
    ok to BUY AP ammo
    ok to SHOOT AP ammo
    NOT ok to MAKE AP ammo (18 USC sec. 922(a)(7))
    NOT ok to IMPORT AP ammo (18 USC sec. 922(a)(7))
  13. Lee1959
    Hmmmm, that is good to know :). Thanks :) I just got back from the range a short bit ago where I ran 50 rounds of Fiochi FMJ through it, along with sundry other rounds in other handguns, and I always enjoy shooting the Mak. It is without a doubt one of those rare rare firearms that you (meaning I) gain an instant affinity for.
    I love my Redhawk, and 1911s, and others, but no other pistol have I been so comfortable with immediately. The Redhawk was like that after I got it worked on but this is the only one that was instantaenous from the first trigger pull.
  14. Sharpdogs
    Sharpdogs Uber Prepared
    I used to keep one the .380 versions as a beside gun.  Great little gun.  I have upgraded to a German Shepherd and .357.  This site has a ton of information on the Makarov pistols  http://www.makarov.com/
  15. Lee1959
    My bedside gun is a .45 ACP loaded with glasser silvers, but I would not feel undergunned with the Mak loaded with the same.
