Leatherman tools are too tight
Discussion in 'MultiTools and Other Pocket Tools' started by James A. Cathcart, Nov 12, 2018.
  1. James A. Cathcart
    James A. Cathcart Loaded Pockets
    I have recently purchased the new black Leatherman Wave+, but man, are the tools tight. I can't pry them out unless I use a prybar. Does anyone know the best lubricant to use to loosen up these puppies?
  2. TheGremlin
    TheGremlin Loaded Pockets
    I have three suggestions, each of which I have used at one time or another.
    1. WD40. Often. I usually lube my various Leathermans about once a week, or every other day for my work user.
    2. You can loosen up the pivot screws just a little bit. If I recall, they take a T10 tamper proof bit.
    3. Work the individual tools a bit. Seriously, just throw on your favorite tv show and open and close the tools over and over for an afternoon.
    Sent from an alternate dimension using Talkatap.
  3. chaosmagnet
    chaosmagnet Loaded Pockets
    I prefer Tuf-Glide to WD-40 for this purpose (I prefer WD-40 as a penetrating oil for stuck fasteners and for displacing water).
    Moshe ben David likes this.
  4. Wishoot
    Wishoot Loaded Pockets
    I used the same stuff I use on my firearms. Ballistol. Works great.
    But I would imagine that any decent penetrating oil would do the trick.
    JeffVenture and chaosmagnet like this.
  5. the lone gunman
    the lone gunman Empty Pockets
  6. James A. Cathcart
    Thank you so much guys, I appreciate your help!
  7. smokingfish
    smokingfish Loaded Pockets
    I find that opening and closing them for a period of time works best, lubricants might make them too loose over the long run.
  8. Scribble
    Scribble Loaded Pockets
    I asked leatherman and they said to soak the tool in some light machine oil for 24 hours, dry off then repeat up to 3 times if needed. My wave is so tight in the pliers area that I collapse the handles when trying to open the pliers.
    chaosmagnet likes this.
  9. chaosmagnet
    I'd definitely loosen the pivots as well.
