Leatherman Squirt Mod
Discussion in 'Do-It-Yourself & Gear Modifications' started by ceweale, Oct 8, 2008.
  1. ceweale
    ceweale Empty Pockets
    After seeing some of the key modifications to the Micras I decided to try it on a Squirt. I followed the same formula that seems to work on the Micras. Take the tool apart (had to grind the rivets on the Squirt), use a tool as a template to modify / grind the keys and re-assemble.
    I re-assembled mine using #6 stainless machine screws and nuts. I would like to use a threaded tube with screws on each side so that the tools can be removed while the threaded tube stays in place holding the pliers in place. Unfortunately I haven't been able to locate such a small threaded tube (roughly 1/8" outside diameter). Any help in locating such a tube (or other ideas) would be appreciated.
    Here is the Squirt.
  2. Rochefort
    Rochefort Loaded Pockets
    That's a cool mod. O0
    I've been wanting to do the the same, but unfortunately, Abloy-keys wont fit in the "toolslots" that squirt has. I modded my Micra last spring, but I would really lie to have my keys on the outside, not on the inside as Micra has them.
  3. parnass
    parnass Loaded Pockets
    :welcome: Welcome to EDC Forums, ceweale. Good first post.
  4. RyanMalpiede
    RyanMalpiede Loaded Pockets
    Very nice work ceweale ... how long did it take you to mod? Might have to try the same.
  5. fishwolf
    fishwolf Loaded Pockets
    Nice! Welcome to EDCF!
  6. max6166
    max6166 Loaded Pockets
    Very inventive! O0
  7. ceweale
    It took me most of an evening to do the work. I had picked up the machine screws and copied the keys in advance so all I had to do was grind out the rest of the rivets (I had taken one out to measure so I could get the screws) and cut down / grind the keys.
  8. bruner
    bruner Loaded Pockets
    Nice work!
    :thumbsup:
    Dan
  9. ceweale
    Small correction. The machine screws I used were #4, not #6. I found some round aluminum standoffs at digikey and turned them down a little (they were too big) using a drill and a bench grinder and now I have a #2 screw on each side instead of a screw and a nut. As a bonus, it is a little closer in diameter to the rivit that was removed so the pliers work a little more solid. Thanks.
  10. pmeowned
    pmeowned Empty Pockets
  11. b.licious
    b.licious Loaded Pockets
    Sorry for the necro post. I just got a squirt myself. What tool would you use to grind down the rivets?
  12. metropolicity
    metropolicity Loaded Pockets
    Try using the rods for body jewelry, they are threaded and come in various sizes.
  13. solrikioo
    solrikioo Loaded Pockets
