I need a good flashlight for keychain/pocket EDC
Discussion in 'Flashlights & Other Illumination Devices' started by lmbc2, Aug 7, 2008.
  1. lmbc2
    lmbc2 Loaded Pockets
    I have probably about 20 flashlights, but all are pretty basic and generic. I am interested in getting a nice flashlight for EDC in my pocket. Ideally it would be good for both standard lighting and some fairly bright lighting for SD or such. I am less concerned about what type of batteries it takes and the price, although I don't want to spend money unnecessarily.
    Can anyone help me find a great flashlight? Thanks.
    Recommend a Flashlight Checklist: (Don't worry about all the questions, just the ones you feel strongly about!) Please mark "x" inside the [ ] to indicate your choice.
    [x] I will be mail-ordering or buying online, so this doesn't matter.
    [ ] I am in _______(country) and __________(state/providence).
    3) Price Range: An easy question, but you may change your mind after answering the rest! broke
    [ ] $1-15
    [ ] $15-30
    [x] $40-60
    [x] $80-$120
    [x] $120-$250
    [ ] I have no limit!
    4) Format:
    PART A
    [x] I want a flashlight.
    [ ] I want a headlamp.
    [ ] I want a lantern.
    PART B
    Length:
    [x] 1-2 inches. (Keychain sized)
    [x] 2-4 inches. (Pocket carry)
    PART C
    Width:
    [ ] I prefer a long narrow light.
    [x] Doesn't matter.
    PART D
    Weight:
    [ ] Very light, can't tell it's there.
    [ ] Light, no heavier than a few keys or a small car remote.
    [ ] Medium light, about the weight of a AAA MiniMag
    [x] Medium, slightly heavier than a AA MiniMag
    [x] Heavy Medium, can of Coke
    [x] Heavy, PDA or small digital camera
    5) What kind of "bulb".
    [ ] LED - more rugged, unlikely to burn out in your lifetime, less accurate color rendition, in general less output but more efficient (longer runtimes)
    [x] Don't care, just want the best fit for my needs.
    [x] I want common Alkaline batteries. (AA, AAA, C, D)
    [x] I want lithium batteries. (coin cells, CR123, AAA, AA...)
    [x] I want to read a map, find a light switch/keyhole, or get around the house at w/o disturbing anyone. (5-10 lumens)
    [ ] I want to walk around a generally paved area. (15-20 lumens)
    [ ] I want to walk unpaved trails. (40 lumens)
    [x] I want to light an entire campground or dazzle an intruder. (100+ lumens)
    Throw (distance)-----------------x-----|----------------------Flood/close-up
    9) Runtime: Not over-inflated manufacturer runtime claims (like some LED lights). but usable brightness measured from first activation to 50% with new batteries. Understand that runtime is a function of brightness and capacity of your batteries. If you want 6 hours you'll either have big batteries or dimmer light, they haven't made a setup yet that lights up like the sun, runs all night, and fits in your watch pocket. wink
    [x] 20 min. (I want the brightest light for brief periods)
    [x] 60-240 min. (1-2 hours)
    [ ] 240-360 min. (4-6 hours)
    [ ] Slightly Important (Walks around the neighborhood.)
    [x] Very Important (Camping, Backpacking, Car Glove-box.)
    [x] Critical (Police, Fire, Search & Rescue, Self-defense, Survival.)
    11) Switch Type:
    [ ] I don't care.
    [x] sliding switch (Stays on until slid back.)
    [x] clickie switch. (Stays on until pressed again.)
    [x] rotating switch
    12) Switch Location:
    [x] I don't care.
    [ ] I want a push switch on the back end of the body.
    [ ] I want a remote control.
    [x] A simple on-off is fine for me.
    [x] I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
    [x] I want multiple light levels. (some lights have 5-16 light levels.)
    [ ] I want S.O.S. flashing
    [x] I don't care.
    [ ] Waterproof – how deep: _____________
    [ ] Belt/Jacket clip
    [ ] Holster
    [ ] Wrist/Neck Lanyard
  2. carrot
    carrot Loaded Pockets
    Consider the Ra Twisty or Ra Clicky. They are good tough reliable lights and offer all the features you list.
  3. insaned
    insaned Loaded Pockets
    Go here and buy a RAW version - www.lummi.co.uk/
    Contact Rob first to email, to check availability tough
    The best and smaller light you can get.
    Think twice about putting tritium in it if you really will EDC it, or at least cover the tritium vials with a small coat of epoxy. Iv you don't wanna risk, just don't buy it with trit!
    best because:
    -small and very well built
    -waterproof
    -20/200 lumens
    -rechargeable
    the only problem is when you buy one, you want all the models :D
  4. jojobos
    jojobos Loaded Pockets
    You can look into EX10 D10 from 4sevens.com. They are best bang for the buck I think. They are also have good regulated output.
  5. bruner
    bruner Loaded Pockets
    +1 on that
    I am so happy with my EX10!
    Dan
  6. lmbc2
    I have read about those a bit. The D10 looks pretty sweet, especially because it takes the AA batteries. Any reason why I should go with the EX10 over the D10? Also, what about pocket clips or similar carrying options? I don't really want to carry it on my keys or in the bottom of my pocket.
  7. MandM
    MandM Loaded Pockets
    Keychain EDC? How about a Fenix E01?
    Great little light... perfect for keychain carry... and at <$15... can't beat the price.
  8. jojobos
    There was a talk about 4seven releasing the clip for them but I don't know what is the deal now. I actually should have recommended D10 over EX10. I picked EX10 mainly because I have many RCR crc123 lights. EX10 is bit shorter but wider than D10. D10 can take commonly available regular AA and lithium as well.
    I carry my EX10 in FenixP1D holster. My other EDC light is LF2X I carry with a clip or on a keychain.
    If you want a light with a nice clip, JET-I pro IBS (AA light) is very nice. I really like their IBS circuit. You can program lowlow and super high and also have SOS and strobe.
    Liteflux LF2X (AAA light)has similar programmable UI but can be complicated to set up.
    They are plenty bright and the body is very compact but runtime is much shorter compare to D10/EX10.
    This is just my opinion. I hope I didn't confuse you too much.
  9. ADK031
    ADK031 Loaded Pockets
    This light is amazing in terms of size, weight, power and price, very happy with mine.
    [link]
    Shortened link.
    Please see "How to shorten a link to just a word or phrase" in THIS thread.
    :db:
    - bruner
  10. DB
    DB Kilted Moderator
    As many have stated already, the D10 or EX10. I picked up my EX10 first, and was so happy with it, I got a D10 shortly after that.
  11. flip
    flip Empty Pockets
    My little carry lights are an Orb Raw NS, a Gerber Sonic and a Streamlight Microstream.
  12. Rawls
    Rawls Loaded Pockets
    If you want a true keychain light I would heartily recommend the Arc AAA-P. There are better lights, but they are vastly more expensive (like five to ten times as much). At $39.99 my Arc AAA-P is probably one of best values I own, including my house, car, and a basement full of power tools. I would have paid three or four times more for the light.
  13. Titus117
    Titus117 Empty Pockets
    I suggest a SureFire E1B. I love mine! Check them out! Mine's in my pocket every day and night ;)
    Good Luck :highfive:
  14. maxray
    maxray Loaded Pockets
    I really really like my new pocket EDC - the Fenix L0D Q4 I bought a $15 E01 on a whim to try out a 1xAAA light, and fell in love with the form factor, but wasn't crazy about the beam or brightness. The L0D seemed like the logical next step... And sure enough, it has exceeded expectations. I had been carrying my Fenix P2D and then my Novatac 120P and the size was a little too big for true easy pocket carry. For me - the L0D is perfect.
  15. BoxANT
    BoxANT Empty Pockets
    amen to that :D L0D is awesome, never leaves my pocket.
  16. Dixemon
    Dixemon Empty Pockets
    You cant go wrong with any of the recommendations already made. My vote would probably be the EX10 or D10. Clips are supposedly going to be available as a seperate purchase at some point. They are the best bang for the buck going right now. On the other end of the spectrum are the RA lights. Not as pocketable as the nitecore and fenix edc's however, they are truly bulletproof and quite amazing. I have the ra100tr and love it. I throw it in the deep end of the pool and let my kids retrieve it. They have a blast, and Im not even worried in the least bit about the durability of that light.
  17. SheepDog556
    SheepDog556 Empty Pockets
    I really like my Fenix P2D for EDC. It is tiny, but BRIGHT.
  18. lmbc2
    Wow, thanks for the great advice everyone. I think I'm gonna go with the D10 because it is pretty bright, reasonably priced, has lots of great features and an innovative design, takes standard AA batteries and has lots of good reviews and fans. Hopefully they come out with that pocket clip soon... Otherwise maybe I'll hafta make a lanyard or something for it.
  19. jbviau
    jbviau Empty Pockets
    About the D10/EX10 clips, I heard from Matt at Fenix-Store.com that they should be available within a few weeks. Hope so!
  20. Mr_Dave
    Mr_Dave Loaded Pockets
    I'm going to +1 this. I've got a P2D Q5 premium that I carry on my belt or in my pocket, it goes everywhere with me. The having choices of 12 lumens up to 180 lumens means it fills pretty much any daily use I throw at it. The only time in recent memory when I'd wished I'd had my TK10 on my instead of the P2D was when I was at a friends place and somebody in the apartment building across the street was playing with a flashlight lighting up the balcony we were sitting on. :shrug: That's not to say the P2D didn't get him to stop lighting us up, I just would've liked the better throw of the TK10 at the time.
    So whether I need to not trip over the cat in the middle of the night or I need to convince some random guy to stop lighting me up while I enjoy a cigar, the P2D has been there for me.
