Homemade File Knife
Discussion in 'Do-It-Yourself & Gear Modifications' started by JUNK, Feb 20, 2012.
  1. JUNK
    JUNK Loaded Pockets
    Hey, don't really get to post much on here, but just wanted to get thoughts and suggestions on my first file knife I made over the weekend. It still needs polishing and some finish sanding to round out the scales a little better. I made this with an old file, bench grinder and a little 1x30 harbor freight belt sander. Now that I bought the belt sander, I'll have to make a couple more to make it worth the cost. Any ideas for future projects?
    IMG_20120219_161118 by dajunker1, on Flickr
    The pins are from an old screwdriver shaft and the scales are cut from a fiberglass beam used in a waterfront structure design I did at work.
  2. vegassprky
    vegassprky Loaded Circuits
    Looks nice, did you de-temper it?
  3. Dane1957
    Dane1957 Loaded Pockets
    Very nice keep up the good work...Some of my favorite knives started from a file. They were made by RD Nolen Texas
  4. JUNK
    JUNK Loaded Pockets
    No. It took a lot more work to grind and keep cool without annealing and retempering but I wanted to avoid heat treating as I really don't know much about it. I may give it a shot on the next one
    Sent from my LS670 using Tapatalk
  5. JUNK
    JUNK Loaded Pockets
    Thanks. Ill have to check those out. My inspiration was Anza knives made a little bit east of me in east county San Diego.
  6. TCC
    TCC Loaded Pockets
    It looks great! Now it just needs a sheath. ;D
  7. oronocova
    oronocova Loaded Pockets
    Looks good. I've really used the snot out of my 1x30 from harbor freight and it keeps on chugging. I'd buy another tomorrow if it broke today.
  8. JUNK
    JUNK Loaded Pockets
    Thanks. Hoping to get better with practice. I have some kydex laying around but would really prefer leather.
  9. JUNK
    JUNK Loaded Pockets
    Yeah it seems relatively decent. The two year warranty was like 6 bucks so definitely a good buy.
  10. temujin
    temujin Uber Prepared
    "De-temper"? I think you mean "temper", which is what you do to draw out some of the hardness/brittleness from a blade.
  11. vegassprky
    Think I've got dis-temper, you're right!!
  12. ZippoVarga
    ZippoVarga Loaded Pockets
    Heat treating made simple. Having been in the industry for 11 years, I learned enough to be dangerous..lol.
    To "normalize" carbon steel is a process of bringing the item up to it's Austenetic temprature, based on its composition. This aligns the Pearlite and Martensite structure or grain of the metal. A general carbon steel will normalize well at or around 1600 degrees. How do you get it to that temperature? Hot coals or Mapp gas/O2 set up. A generic way to know when you've "sorta" reached this austentic range is when a magnet will no longer stick to the item. BUT.....you actually want to Anneal the file to work it, then Normalize it, then "oil case harden it. To anneal, heat to austenetic temp and slowly let it cool. The best way to do this is to use some bricks, make a small box from the bricks and heat them up. If you're using coals (like in a wood burning stove or a charcoal grill) then use a fan or small blower in the damper to bring the coals to a cherry red, insert the file, then just leave it in there until you can take the file out by hand and not get burnt. This will soften the file to make it (ductile) very easy to work with. After the primary shape is established, before putting the final touches on it, go ahead and Normalize the file. Heat it up until a magnet no longer sticks to it then let it air cool. Do the finishing touches to the blade, then Temper the file. The best way to do this is heat it up with a torch until the blade starts to discolor (turn purple,blue) then dip in used motor oil. Why used motor oil? The phosphates and other minerals that accumulate over the life of engine oil will soak into the surface of the file which will help to give the blade a shallow case hardening (albeit a generic one). You'll find that edge retention will be more evenly distributed over the length of the blade and it won't be so brittle as to snap in half should you need to use it to pry something. There are other ways to accomplish the same degrees of metal conditions during the life of making the blade. These are just the most generic ways to make the process easier on you and your equipment.
    The knife looks AWESOME! I sure hope you continue to make your blades and share them with us here!!
  13. thatotherguy
    thatotherguy EDC Junkie!!!!!
    If I may make a suggestion for your next knife, maybe a skinner if you hunt, or a FFG spearpoint for EDCing.
    Nice work, you did a good job!
  14. Logrus9
    Logrus9 Loaded Pockets
    Thanks for the inspiration, I've got some old files I've been saving to convert into knives. I hope my first attempt comes out as good as yours.
  15. ElChingon7
    ElChingon7 Loaded Pockets
  16. JUNK
    JUNK Loaded Pockets
    Thanks very much for the insight. This process seems like it may take quite a bit of practice to get decent results. Do you think that the file left as is is too brittle for duty as a knife?
  17. JUNK
    JUNK Loaded Pockets
    The shaping is not too bad. If you just take your time and grind slowly it seems to go ok. With a thicker file, you can afford to make a few mistakes without loosing too much material and still have a fairly thick blade.
  18. JUNK
    JUNK Loaded Pockets
    Thanks, I'm going to make another possibly this Sunday if I can find time or the weekend after. Tough to find time to play around as I've been traveling for work a lot lately. I'll post another pic when its done.
  19. Ren
    Ren Loaded Pockets
  20. Kilted1
    Kilted1 Loaded Pockets
    Love the knife! Been thinking of doing one myself. Nothing so satisfying as using something you made yourself.
