Help me pick a new flashlight - Flashlight Recommendation Checklist
Discussion in 'Flashlights & Other Illumination Devices' started by elkhills, Sep 5, 2018.
  1. elkhills
    elkhills Loaded Pockets
    Here are my answers as best I can from the "Help me pick a new flashlight" sticky thread:
    Hello flashlight people, I am looking for some help picking out my next light. I am a long time edc'er and forum member, but flashlights are one thing I am not very knowledgeable about. I have a few little aaa lights that rotate in and out sometimes, and a little Photon light thats always on my keychain, but I think I want to try something a little beefier this time.
    What I think I want is a AA sized light that I might carry in a pocket or maybe even in a belt sheath next to a multitool. Back in the day I rocked the old Mini Mag/Leatherman combo for many years, I kind of have the 2018 version of that in mind, but if pocket carry is easier or more comfy I admit thats what Ill probably do.
    I would think a common AA battery would be best but if there are rechargeable options nowadays that might be even better. I work in an oil refinery, so something intrinsically safe would be ideal, but this is not a deal breaker. This light will be for personal use.
    x I will be mail-ordering or buying online, so this doesn't matter.
    [ ] I have no limit!
    4) Format:
    PART A
    [ ] I want a flashlight.
    PART B
    Length:
    [ ] 2-4 inches. (Pocket carry)
    PART C
    Width:
    [ ] Doesn't matter.
    PART D
    Weight:
    [ ] Medium, slightly heavier than a AA MiniMag, or a little less
    5) What kind of "bulb".
    [ ] I want common Alkaline batteries. (AA, AAA, C, D)
    I dont know. A medium general multi purpose amount of light should be fine.
    Throw (distance)----------------------|----------------------Flood/close-up
    [ ] Very Important (Camping, Backpacking, Car Glove-box.)
    11) Switch Type:
    [ ] I don't care.
    12) Switch Location:
    [ ] I don't care.
    [ ] A simple on-off is fine for me.
    [ ] I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
    [ ] I don't care.
    [ ] Waterproof – how deep: 1 meter
    [ ] Belt/Jacket clip
    [ ] Holster
  2. leathermaneod
    leathermaneod Loaded Pockets
    I’m really loving my new streamlight microstream usb. Very bright on high, starts in low which is perfect for me. I was able to purchase a second battery for about $5.99 online. Highly recommend it, if it checks all your boxes.
    Moshe ben David likes this.
  3. SOS24
    SOS24 Loaded Pockets
    My go to AA lights are Eagletac D25A and Fenix LD12. Both are good quality lights that give you a variety of modes and brightness levels to suffice for most tasks.
  4. elkhills
    Thank you guys. One that has caught my eye is Olight S30R III, what do you think of it?
  5. leathermaneod
    For a pocket light, I would avoid anything with a side switch like that. I gave an Olight s1 mini a try a couple weeks ago and really liked it, until i found it turned on in my pocket. I did some experiments and couldn’t figure out how it could have happened, so I gave it another shot. Well a week later I went to pull it out one time and found it dead, so I had to go back to tail switch. That’s when I got the Microstream. I’m still a little disappointed at loosing the magnetic tail cap, but the Microstream is perfect otherwise.
  6. turbo6
    turbo6 Loaded Pockets
    Fenix E12
    Fenix LD12
    Thrunite Archer 1A
    Thrunite T10
    Also, some of AA Zebralights have some great low modes too.
  7. Water-Rat
    Water-Rat Loaded Pockets
    As mentioned by Turbo, if you have the cash for a Zebralight ($60-$80), they are very versatile and bright AA lights. I have the H53c which is an amazing angle light/headlamp. The versatility of these lights and the ability to select any mode from off is quite nice. Zebralights do have side switches (or top switches for angle lights), but they are recessed into the body and are hard to hit accidentally.
    Nitecore has a couple AA lights in their multi task series. These lights are in the $40-$50 range. I own a MT2A, the 2xAA version and it is a very nice poor man's tactical flashlight. The MT1A and MT2A have a pair of modes changed by twisting the bezel, one mode gives you turbo with a momentary click and the other lets you tap through H, M, L, Strobe, and beacon modes. They also have more expensive lights (MT10A) that will run on either a AA or a 14500.
    I just ordered the new version of the Klarus XT1A for $50. It will run on a AA, but comes with a USB rechargeable 14500. I decided on this light because I was looking for a small AA size light that could easily be manipulated by one hand only. The XT1A has a dual tail switch, which lets you access either high or low from off or in a tactical mode, high or strobe.
    The Fenix E12 that Turbo mentioned is a solid light as well. I gave my Mom one to use as a purse light. Nice cheaper ($30) edc light with a decent L/M/H mode setup.
  8. ProjeKtWEREWOLF
    Olight s1A. I have the S1mini and live the UI. I will be buying the A model very soon.
