Help choose my EDC torch
Discussion in 'Flashlights & Other Illumination Devices' started by musicman13, Jul 22, 2012.
  1. musicman13
    musicman13 Loaded Pockets
    Flashlight Recommendation Checklistby CPFer ThomasH with edits and additions by EDCF members
    Recommend a Flashlight Checklist: (Don't worry about all the questions, just the ones you feel strongly about!) Please mark "x" inside the [ ] to indicate your choice and please delete the options that you are not at all interested in.
    Basic EDC uses for finding my way around in the dark, and occasionally at work.
    [x] I will be mail-ordering or buying online, so this doesn't matter.
    [ ] I am in _______(country) and __________(state/providence).
    [ ] $1-15
    [x] $15-30
    [ ] $40-60
    [ ] $80-$120
    [ ] I have no limit!
    4) Format:
    PART A
    [x] I want a flashlight.
    [ ] I want a headlamp.
    [ ] I want a lantern.
    PART B
    Length:
    [x] 2-4 inches. (Pocket carry)
    PART C
    Width:
    [x] I prefer a long narrow light.
    [ ] Doesn't matter.
    PART D
    Weight:
    [ ] Very light, can't tell it's there.
    [x] Light, no heavier than a few keys or a small car remote.
    [ ] Medium light, about the weight of a AAA MiniMag
    [ ] Medium, slightly heavier than a AA MiniMag
    [ ] Heavy Medium, can of Coke
    [ ] Heavy, PDA or small digital camera
    5) What kind of "bulb".
    [x] LED - more rugged, unlikely to burn out in your lifetime, less accurate color rendition, in general less output but more efficient (longer runtimes)
    [x] I want common Alkaline batteries. (AA, AAA, C, D)
    [ ] I want lithium batteries. (coin cells, CR123, AAA, AA...)
    [x] I want to walk around a generally paved area. (15-20 lumens)
    [ ] I want to walk unpaved trails. (40 lumens)
    [ ] I want to light an entire campground or dazzle an intruder. (100+ lumens)
    Throw (distance)-------------------x--|----------------------Flood/close-up
    [x] 60-240 min. (1-2 hours)
    [ ] 240-360 min. (4-6 hours)
    [x] Slightly Important (Walks around the neighborhood.)
    [ ] Very Important (Camping, Backpacking, Car Glove-box.)
    11) Switch Type:
    [ ] I don't care.
    [x] clickie switch. (Stays on until pressed again.)
    [ ] rotating switch
    12) Switch Location:
    [ ] I don't care.
    [x] I want a push switch on the back end of the body.
    [ ] I want a remote control.
    [x] A simple on-off is fine for me.
    [ ] I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
    [ ] I want S.O.S. flashing
    [x] I don't care.
    [ ] Waterproof – how deep: _____________
    [x] Non-reflective/dark finish (stealthy/hard to find)
    [x] Belt/Jacket clip
    [ ] Holster
    [ ] Wrist/Neck Lanyard
  2. Racer
    Racer Loaded Pockets
    Not a lot of lights that fit your criteria in that price range.
    You could pick up a Jetbeam BA10 (AA) for about $35
    Streamlight Microstream (AAA) is about $20. I think this might be the light you are looking for.
    Or, you could go the super cheap route with a UniqueFire S10 (if you like throw) or UltraFire K10 (if you like flood) for about 10$-$15. I give a lot of these away as gifts. They are cheap but powerful and rugged, and make great starter EDCs.
    There's some great EDC AA twisties out there as well: Thrunite T10, Fenix E11, Olight I2...
  3. reppans
    reppans Loaded Pockets
    E series Fenix from the forum store... lots of different flavors in cheap, tiny, AA/AAAs
  4. grndslm
    grndslm Loaded Pockets
    For $30...
    Buy 3 or 4 of these...
    http://www.dealextreme.com/p/small-sun-zy-a29-cree-q3-wc-3-mode-150-lumen-white-zoom-convex-lens-led-flashlight-1-x-aa-90635
    I have bought a few DX lights before, and what's strange is that this is the cheapest, yet it's the MOST mission critical of them all. It's plenty bright for me.
    I bought the TrustFire red flame 14500 lithium ion batteries (also on DX), which definitely increases the light output for something that's only the size to hold and actually does run off of AA batteries.
    The SkyRay S-A1 ... and .. UniqueFire G10 both have their good sides, too... but have yet to be as "failproof" as the Small Sun flashlight I linked to. If the first two were good "enough" to work for carrying, then I'd use them... but even after using NyoGel, they have to stay at home or in the car. :)
    P.S. -- you also need an Lithium-Ion charger, and I'd recommend the XTAR WP2.
    You're actually capable of getting the light, charger, and 2 li-ion batteries for around $30 if you look around. Think I got the charger on ebay??
  5. D50boy
    D50boy Loaded Pockets
    Preon1 with a Preon2 tail switch. It would be in the next price category though.
  6. Flash Owl
    Flash Owl Loaded Pockets
    i heard great things about the photon freedom...
    unfortunately mine broke in about a week on my keys... not exactly broke, but most of the time the switch didnt respond.
    streamlight has a AAA light with a tailswitch, 1-mode, and inexpensive.
    couple days ago i was researching simple single AA lights... came across fenix E11, and rofis ER12.
    ICON also makes some inexpensive single AA lights.
  7. Flash Owl
    ack, double post.
    sorry
  8. musicman13
  9. sungame
    sungame Loaded Pockets
    I have
    Yes, I have tried it (although not owned one myself), and it seems like a rugged, dependable little light for a very reasonable price. It is not the brightest light out there, but it is probably the best light you'll ever get for $15, and at least as good as many lights at twice that price.
    If you want something brighter, take a look at Lumapower's EDC LM-21. It actually a bit smaller than the Microstream, but gives you three modes, up to 100 lumen and up to 1500 hours of runtime (on the lowest setting), all for just shy of $30. Nitrofein has a great review of it over in this thread.
    musicman13 likes this.
  10. Racer
    It's a great little light. There's lots of decent reviews floating around, including mine. Most people gripe that the switch is a little stiff (though you can take the rubber boot off) and mine wears the anodizing off the threads, which doesn't affect the functionality for me because I don't use the tail cap lockout. Lots of reviewers claim theirs has been through the wash/dry cycle. It's pretty much bulletproof and idiot proof. I've had mine for a year, and it has held up well. I like the double clip because you can clip it on your pocket normally for deep carry, or reverse clip it onto a ball cap for use as a head lamp. It's got pretty good throw too because of the smooth reflector and the XP-C emitter it uses. People claim that it can take a 10440, but my blue Trustfires won't power the light on. It loves Eneloops, though...
    Edit: There's also the Pelican 1910, which is a very similar light to the Microstream.
