Handheld HAM Radio Antenna
Discussion in 'Electronic Devices' started by resq1192, Oct 29, 2016.
  1. ballistic
    ballistic Loaded Pockets
    And... another supporter of the Signal Stick.
    chaosmagnet likes this.
  2. chaosmagnet
    • Sponsor - Home Craftsman
    chaosmagnet Loaded Pockets
    I've ordered two Signal Sticks to try out on my HTs. Thanks for the recommendation!
  3. syntaxerrorsix
    syntaxerrorsix Loaded Pockets
    If you want any significant improvement you'll need something close to 1/4 wave length. Another vote for Signal Stick. I keep mind rolled up in a knot until I'm in the field.
    chaosmagnet and ballistic like this.
  4. Ed Humphries
    Ed Humphries Empty Pockets
    Not a fan of the Baofeng - they haven't met basic spectral testing standards from the get-go. The sound terrible to me. But that's apparently okay since people can buy them cheap and use them on freqs they shouldn't at illegal power levels for those bands. Ask a GSMA repeater owner what they think about the Baofeng (and be prepared for an earful). But all that is off-topic.
    I like the Diamond ht antennas also. Nagoya's can be good performers. Talking about the @19inch models, of course; no stubby duck can compare. There are two caveats: one, double check - clone makers are labeling cheaply made antennas that don't last and don't perform as Diamond/Nagoya, two, do a scan for each band to check out the antenna. I've found several to be good (within the limits of an ht antenna) on the 70cm band but terrible on 2m band (as in resonant at >170MHz). I found one "dual band" (which I thought was a Diamond) that is only resonant on 220. I ended up using a 2m only antenna (properly resonant in band) when performance on that band is important.
    I second the use of a "tail" to help the performance of the antenna. I also use a "pocket j-pole" hung up high and in the clear when performance is critical (I know its performance curve intimately because I built and tuned it myself - if you buy one, test, test, test.)
    And finally, for those who might not know/realize what they are doing. Your antenna performance is going to s going to be bad if you hold the ht such that the antenna is parallel (or nearly so) to the ground. Those are vertical antennas folks; point 'em UP. Movies and TV mess this up constantly.
    Cheers, Ed H. - Atlanta
