Flashlight recommendation?
Discussion in 'Flashlights & Other Illumination Devices' started by ?uesto, Apr 13, 2010.
  1. ?uesto
    ?uesto Loaded Pockets
    Camping/outdooring, navigating my house/property at night, and to have on me when going somewhere at night. Just in case.
    [x] I will be mail-ordering or buying online, so this doesn't matter.
    [x] I want to try a light in person first, and I am in The U.S. in Florida.
    3) Price Range: An easy question, but you may change your mind after answering the rest!
    [ ] $1-15
    [x] $15-30
    [x] $40-60
    [ ] $80-$120
    [ ] I have no limit!
    4) Format:
    PART A
    [x] I want a flashlight.
    [ ] I want a headlamp.
    [ ] I want a lantern.
    PART B
    Length:
    [x] 2-4 inches. (Pocket carry)
    PART C
    Width:
    [ ] I prefer a long narrow light.
    [x] I prefer a short wide light.
    [ ] Doesn't matter.
    PART D
    Weight:
    [ ] Very light, can't tell it's there.
    [ ] Light, no heavier than a few keys or a small car remote.
    [x] Medium light, about the weight of a AAA MiniMag
    [x] Medium, slightly heavier than a AA MiniMag
    [ ] Heavy Medium, can of Coke
    [ ] Heavy, PDA or small digital camera
    5) What kind of "bulb".
    [ ] LED - more rugged, unlikely to burn out in your lifetime, less accurate color rendition, in general less output but more efficient (longer runtimes)
    [x] Don't care, just want the best fit for my needs.
    [x] I want common Alkaline batteries. (AA, AAA, C, D)
    [x] I want lithium batteries. (coin cells, CR123, AAA, AA...)
    [x] I want to walk around a generally paved area. (15-20 lumens)
    [x] I want to walk unpaved trails. (40 lumens)
    [ ] I want to light an entire campground or dazzle an intruder. (100+ lumens)
    Throw (distance)-----------------X-----|----------------------Flood/close-up
    [x] 60-240 min. (1-2 hours)
    [ ] 240-360 min. (4-6 hours)
    [x] Slightly Important (Walks around the neighborhood.)
    [x] Very Important (Camping, Backpacking, Car Glove-box.)
    11) Switch Type:
    [ ] I don't care.
    [x] clickie switch. (Stays on until pressed again.)
    [ ] rotating switch
    12) Switch Location:
    [ ] I don't care.
    [x] I want a push switch on the back end of the body.
    [ ] I want a remote control.
    [x] A simple on-off is fine for me.
    [x] I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
    [ ] I want S.O.S. flashing
    [x] I don't care.
    [x] Waterproof – how deep: Not too deep. Nothing for diving or anything... Figure 100' at the most?
    [x] Belt/Jacket clip
    [ ] Holster
    [ ] Wrist/Neck Lanyard
    [x] Kuboton/self defense features... Or at least interchangeable heads
  2. Ajax
    Ajax Loaded Pockets
    100' is not too deep?
    I would say, up until that, look at the 4Sevens Quark or Fenix flashlights.
  3. ?uesto
    To be honest, I'm not sure of the water requirements. Again, I'm not going diving, I guess worse case scenario would be my car driving into a small lake or having to go rescue someone in that situation.
  4. jsmitty1967
    jsmitty1967 Go Big Blue
  5. MedXLT
    MedXLT Empty Pockets
    I'd check out the Quarks as Ajax has suggested or the P-series EagleTac lights. I hear the P20C2 is a great light!
  6. ?uesto
    Thanks for the recommendations guys. I actually found a few Surefire models that fit my price range, (I had no idea they made any models under $100). Anyone have any good word on these?
    6P Original
    G2 Incadescent
  7. Ajax
    Ajax Loaded Pockets
    I've got a couple G2 Nitrolons.
    The tailcap switch is only a momentary on, to get constant on you have to tighten the tail down.
    Only one brightness level.
    Not sure about the water resistance ability.
    Conversely, all Surefires are extremely modifiable(?).
    You can get all kinds of LED drop-ins for them, clicky tailcaps can also be found.
  8. carrot
    carrot Loaded Pockets
    6P and G2 are classics, but they do not really compare well to modern LED-based flashlights.
    Good news is for some extra money you can easily upgrade the heck out of them and end up with a real barn burner. One of my favorite setups is the 6P with a Malkoff LED module, which essentially doubles the cost of the light but with 300 OTF lumens, well... it's worth it.
  9. mtwarden
    mtwarden Loaded Pockets
    if your thinking about the G2, I'd also consider the G2L- well under a $100 as well
