Another flashlight
Discussion in 'Flashlights & Other Illumination Devices' started by Gypscoprotheres, Aug 28, 2015.
  1. Gypscoprotheres
    Gypscoprotheres Loaded Pockets
    I'm looking for a flashlight to carry in my Vanquest EDCM Husky. In my other thread I was also looking for that and I ended up with the NiteCore Tube, which is a very nice little flashlight in my opinion and now used as a key chain light.
    I've decided to carry the Tube on my keyring and now I'm looking for a larger and more sturdy one to carry in my organizer. I would like to use it on travels, on camping trips, in the forest, around the house. I would really like to have an all-round flashlight.
    [V] I will be mail-ordering or buying online, so this doesn't matter.
    [V] I am in The Netherlands.
    [V] $1-15
    [V] $15-30
    4) Format:
    PART A
    [V] I want a flashlight.
    PART B
    Length:
    [V] 4-6 inches (+/-).
    PART C
    Width:
    [V] I prefer a long narrow light.
    [V] I prefer a short wide light.
    Is there something in between?
    PART D
    Weight:
    [V] Medium light, about the weight of a AAA MiniMag
    [V] Medium, slightly heavier than a AA MiniMag
    5) What kind of "bulb".
    [V] Don't care, just want the best fit for my needs.
    [V] I want a rechargeable system. (an investment, but best for everyday use)
    Rechargeable batteries would also be OK.
    [V] I want to read a map, find a light switch/keyhole, or get around the house at w/o disturbing anyone. (5-10 lumens)
    [V] I want to walk around a generally paved area. (15-20 lumens)
    [V] I want to walk unpaved trails. (40 lumens)
    Throw (distance)--------------X-------|----------------------Flood/close-up
    Not sure about what's the best for my needs.
    9) Runtime: Not over-inflated manufacturer runtime claims (like some LED lights). but usable brightness measured from first activation to 50% with new batteries. Understand that runtime is a function of brightness and capacity of your batteries. If you want 6 hours you'll either have big batteries or dimmer light, they haven't made a setup yet that lights up like the sun, runs all night, and fits in your watch pocket. [​IMG]
    [V] 60-240 min. (1-2 hours)
    [V] 240-360 min. (4-6 hours)
    [V] Very Important (Camping, Backpacking, Car Glove-box.)
    11) Switch Type:
    [V] I don't care.
    12) Switch Location:
    [V] I don't care.
    [V] I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
    [V] I want a metal-bodied light.
    [V] Pocket clip
  2. GatorMedic
    GatorMedic Loaded Pockets
    L3 Illumination L11C :) Metal-bodied, clicky, pocket clip, multiple modes (3-30-140/160 version or 0.09-3-30-140/160 version). All for $33-34.
    No Agenda likes this.
  3. Gypscoprotheres
    Seems like a nice flashlight. Came out this year I see. Is it strong?
    My budget isn't exactly up to $ 30, but more like up to $ 40. I've checked out the Fenix LD09, but I'm a bit of a noob when it comes to choosing flashlights, so I have no idea if this would be a good choice, considering my needs.
  4. Tegan's Dad
    Tegan's Dad Loaded Pockets
    I have the L10C, which was replaced with the L11C. It is my edc, and I really like it. I have the 3 mode version. It always comes on in low, then mid, then high which is my preference. AA battery is easy to come by if you need extras while you are out. I use lithium primaries with it, but I'm guessing eneloops would be great.
    Fenix are known for reliability, and a lot of people really like them. I don't have the LD09 myself, so I can't comment much on it.
    A few more dollars (~36ish) you can get a JetBeam BA10 or BC10. The BA10 is a 1xAA that does 12 or 160 lumens. Loose front bezel for low, tight front bezel for high, and a tail clicky for on/off. You can use momentary on the click if you like. The BC10 is similar, but with CR123A. I forget the numbers, but it's something like 30 lumen low and 240? high. These would be thicker than the L11C, which is a pretty slim light.
    A lot of times, slim lights are more floody, and thick lights are more throwy (bigger, deeper reflectors).
    Olight would be another good one to look in to. I used to EDC the olight i3s (maratac AAA is the predecessor) before I found out the L10C fits in my skinth tube. It's tiny and still has a decent output, though you'll do more output longer with a AA.
    GatorMedic, No Agenda and Water-Rat like this.
  5. Gypscoprotheres
    Thank you for the advises. I'll look into these flashlights for sure. :)
    Tegan's Dad likes this.
  6. GatorMedic
    Both the L3 Illumination L11C and Fenix LD09 are great choices. I carry the L11C as my EDC and before that I had the earlier model L10C that I EDCed. I also have the Fenix LD12 (predecessor to the LD09), and it's a good light too.
    Gypscoprotheres and No Agenda like this.
  7. Gypscoprotheres
    I've changed my mind about the price: A maximum of € 100 now.
    I also would like it to be able to tail stand and use regular AA batteries (easy to find.
  8. ZMZ67
    ZMZ67 Loaded Pockets
    Not sure what the conversion rate is but the Zebralight SC52 probably falls in the range ($64 US).The SC52 runs on any AA (Alkaline,NiMH,Lithium or Li-ion14500).I don't have the SC52 but I do have the higher output Zebralight SC5w and have been impressed with it so far.The SC5 is worth a look but you are pretty much married to NiMH rechargables(I use Eneloops),Energizer lithiums will work though.Alkaline AAs always leak for me so I avoid using them,something to consider if your spending money on a decent light.
    Gypscoprotheres likes this.
  9. Gypscoprotheres
    Nice! First I thought that I wouldn't find this Zebralight here in the Netherlands, but I've found it.
    There are some varieties of the SC52 (SC52w L2, SC52F L2, SC52Fw L2 and the SC52d High CRI Daylight AA)
    What's the difference between the SC52-s? I've seen some different lets, but I have no idea of which meet my needs the best.
  10. Gypscoprotheres
    I should do some more research before asking stuff! :confused:
    F = Flooded
    W = White (cool or neutral)
    D = Daylight
    I've decided to go for the flooded one. I'm only having doubts between cool white and neutral white (daylight confuses me a little bit. Seems to me that should be neutral or warm white. No idea!).
    When do you use cold white and when neutral white? I can imagine that you'll be able to see colors much better with neutral light.
  11. EZDog
    I would suggest that you not get the flood version for your first go at the Zebra.
    These are really fairly floody in normal form and I think you might end up with a lot less light than you expect if you start off with the diffused flood option here.
    You can always make the standard light more floody with a little scotch tape later but you will not be able to un-flood the floody one if yo get the built in diffusion.
    I would also go for the 52w version as it is Neutral and not cool as listed above?
    The plain SC52 is cool
    I have both and really prefer the W as it just makes things look natural especially outside while camping.
    I find the D daylight a little warm for my tastes but you might prefer that? All I know is that the neutral is right in the middle and a great tint for me.
    I work with wiring all day and the N lets me see the real colors coded on the wire unlike any Cool that I have used.
    ZMZ67, Gypscoprotheres and kikissabiz like this.
  12. Gypscoprotheres
    Thanks. I'll go for the SC52w!
