Advice needed
Discussion in 'Keychain Tools' started by Krs, Dec 14, 2015.
  1. Krs
    Krs Loaded Pockets
    Hi EDC'ers
    I need some advice. I have my keychain with 9 key and some gadgets like mini-torch, clip, spare keyring, etc and I really like it. It has some weight however. When I go for a run I would need a MINIMAL set up. Like 1 key to front door :) my keychain is just too heavy to run with. Is there any quick and easy solution to switch between my regular keychain and 1-key-solution? Like a clip or any detachable gadget. Having 2 front door keys is not my taste.
    sent from my microwave owen using tapatalk
  2. Ataki
    Ataki Loaded Pockets
    I use a couple of quick disconnects.
    They do add a bit of bulk to the keychain, but i'm pleased with them.
  3. Krs
    Krs Loaded Pockets
    Finally I got 2 of these. Quick and easy solution to disconnect single key.
    Ataki likes this.
  4. davidkoleda
    davidkoleda Loaded Pockets
    Don't these type of quick release add a lot of bulk to the keychain?
    Ben Rubinstein likes this.
  5. Krs
    Krs Loaded Pockets
    They do. But I am ok with having some extra weight. When i need to disconnect (ie I go for a run) it is really quick and easy to unlock.
  6. Claptrap
    Claptrap Loaded Pockets
    freekey makes it easy to disconnect individual items from your keyring without relying on clips.
    If you want to go the clip route, McGizmo clips or Tec Python clips are very nice.
  7. flatline
    flatline Loaded Pockets
    I solved that same problem with Nite Ize s-biners. Now I can easily remove any item from my keychain (particularly useful when the keys are in the ignition of my vehicle).
    The S-biners make the keychain a little larger, but do not noticeably add weight. I had some concern about their robustness, but haven't had any issues with them in the 2 or 3 years that I've used them.
  8. TheGremlin
    TheGremlin Loaded Pockets
    I just had an extra door key made for situations like this. Easy enough to grab, and no fussing around with taking stuff off and on all the time.
    Some assembly required, batteries not included!
    Eskerbillion, chmsam and Krs like this.
  9. Narcosynthesis
    Narcosynthesis Loaded Pockets
    If it is just a house key you want to carry, the simplest option would probably be to just get a spare made - this would also let you attach whatever you want to it to make it easy to carry - a clip or safety pin to keep it fixed in a pocket, chain to wear around your neck or whatever.
    If you would rather have something removable, then I would look to a small clip like the McGizmo (though I would avoid the smallest size) - stick that on the keyring and you can easily attach and detach your key as required.
    Al Effendi likes this.
  10. bnate
    bnate Loaded Pockets
    Another option: Google "air coupler key chain" I have a few in my backpack and one on my keychain. They are a very sturdy disconnect option. Haven't had a failure yet, however have had other types fail on wife's keychain.
    Good luck.
    Krs likes this.
  11. Al Effendi
    Al Effendi Loaded Pockets
    The little Ti opener is so cool. All the rings are also Ti. I've been using the gray clips for two months now, and they are rock solid. Not as well-designed as the Python (with its no-catch clip), but cheaper than dirt.
    Sampo swivels are the best. Not only do they help keep the whole mess from getting stuck in my pocket, it makes a fun spinny mobile for when I'm bored.
    Nick4305 and Krs like this.
  12. Krs
    Krs Loaded Pockets
    This picture reminds me to my Mag Mini what I lost :(
