Glock 17 simulator
Discussion in 'Handguns' started by 95yjinpa, Dec 28, 2012.
    • +3 Supporter
    95yjinpa Uber Prepared
    Pretty neat. Get it here.
    billybag and SurvivePenna like this.
    ac7ss Uber Prepared
    Wrong method of resetting after the last round lockback. SPD armorer instructed me that using the holdback lever causes wear. just rack the slide again.
    • +1 Supporter
    SurvivePenna Uber Prepared
    Must have fired 200 rounds off....:rofl: Thanks ! :D I was pretty fast reloading in the end....
    Stinger Empty Pockets
    It really shouldn't. There are guys out there with 10's of 1,000's of fired rounds through their Glocks (like me) who've never had a problem. The usual argument is whether or not to go, 'hand-over-top' (HOT) in order to release the slide, or to just use your thumb to release the slide stop. (Which Glock, GmbH is now calling a, 'slide release' - Ahh, the power of gaming!) :D
    'Reset' is, also, a term that applies mostly to a Glock's trigger mechanism. Which is, as far as I know, the only thing that ever actually, 'resets' on a Glock. The slide is most often either, 'racked' or simply, 'returned-to-battery'.
    ac7ss Uber Prepared
    I agree that it shouldn't, but I respect the armorer (It's her fault I went Glock.)
    You are right, reset is more the trigger function (and one of the things that won me over to the Glock, same armorer.)
    I will likely never be in a situation where I have to do a combat reload. I don't even shoot competitively. So I don't think it will matter in the long run.
    amacman Uber Prepared
    Its cheap and easy enough to replace if it does. My G21 hasn't after 15k rounds and counting. It worth noting that Glock sells an extended one, so they must acknowledge that its being used to drop the slide.
    And How did they decide on a round count of 12?
    ac7ss Uber Prepared
    It fit the graphic better?
    Monocrom Uber Prepared
    Bit crude but fun.
    • +2 Supporter
    Echo2 Uber Prepared
    For it's intended purpose...to lock the slide back.
    To load....in a stress situation....one should train with the movement that requires the least amount of fine motor skills....cause that will generally go out the window.
    Regardless if they offer one or not....practice the way you will have to use it.
    Evilbunny Uber Prepared
    he has a ton more guns if you go to his page
